I've been reading Daniel's energy monitoring notebook post and I want to do something similar.
I have an SCT013 non-invasive current clamp that outputs 1v. The voltage output is 1v AC so I have used a voltage divider so that it can be measured using an AnalogIn pin. I know that I need to calculate the RMS of the AnalogIn with a sample rate 500Hz.
I have no idea where to start though as this is all new to me. Could anyone offer me any sample code so that I could measure the apparent power load using the SCT013?
Thanks!!
Thanks!!
it depends on the output of the sensor,
If it is a sine wave, then you could sample like crazy for 40 mS,
Find the max value, from Zero current.
Then multiply by 0.7
To convert to RMS (approximately)
I AM assuming 1 volt = 10 amps ?
If you have a data sheet, please add a link, so we can help further.
Hope this helps ...
Ceri
Hope this helps ...
**Ceri
I'm fine on with hardware but don't know how I would sample and calc the RMS.
Thank you.
The one I am using is the 30amp model but there are others. Spec sheet here:
http://iteadstudio.com/store/index.php?main_page=product_info&products_id=57
And this is roughly what I am trying to achieve:
http://mbed.org/users/mbed714/notebook/home-energy-monitor/#c2404
Thank you.
Cookie Policy
Access Warning
Thanks!!
