Connect mbed Console over Ethernet
10 Oct 2011
is it possible to connect to the mbed console (which I can see for Debugging over USB) over Ethernet e.g. SSH or Telnet?
tia Klaus
10 Oct 2011
Hello Klaus,
For debugging, TCP might be difficult, because the TCP-protocol requires extra data-packets, and latency-time may be too long.
But you could use a UDP socket, and write debug data to a port on UDP, using Donatien's example as a guide:
http://mbed.org/users/donatien/programs/UDPSocketExample/5yuvy
You could replace printf("debug_statements");
with
udp.sendto( dbug_str, strlen(debug_str), &hostpcIP );
The latency seems to be about 2.5ms, with these.
A quick "listening" program in Python can print the debug.
10 Oct 2011
Thanks for the quick response, I will try it with the udp method
