I'm trying to use the example2.h code from the MODDMA library to sample an ADC at 100Hz for 15 sec. After the first sample, I need to progress to the next on the buffer and delete the previous one. My code is below, and the interrupts work, the sampling works, but I can't progress through the buffer for the next sample. I think it's either a logic error, or a command like nextLLI.
while (1) { if (dmaTransferComplete || counter>0) { int i, value, channel; if (counter ==1500) { int write = 0; led1 = 1; d = opendir("/sd/data"); //open the directory for data storage. If non existant, create FILE *fp = fopen("/sd/Data/triax.txt", "a");//confirm can access text file for saving. If not there, create if (fp == NULL) { error("Could not open file for write\n"); } while (write<1500) { write++; for (i = 0; i < 3; i++) { value = (adBuffer[i] >> 4) & 0xFFF; channel = (adBuffer[i] >> 24) & 0x3; channel--; if (channel == -1) channel = 2; // Workaround ch num problem. double fVal = 3.3 * (double)((double)value) / ((double)0x1000); // scale to 0v to 3.3v if (channel != 2) { fprintf(fp,"%01.3f\t", fVal); fflush(stdout); } if (channel == 2) { fprintf(fp,"%01.3f\n", fVal); fflush(stdout); } counter--; c++; } } } fclose(fp);//close file and stop accessing SD card led1 = 0; } dmaTransferComplete = false; }
