Hi:
I have been struggling with converting a program that runs on my Arduino over to the mbed. I believe I am very close, but I'm not quite there.
I have a couple of questions from the output that I have copied below. It looks like the code is working (finally) in that I can read tags, however, I am getting the same tag id no matter which tag I read. I will display three output files below as they appear on Tera Term. I also would like to understand why I am getting 7 Readable: 1 messages when I only expect to see one at the beginning of the output.
After the three output files, I have posted the code with the author's notes as the code is from the book Practical Arduino. I have changed some of the code at the beginning of it as the mbed has a fully available serial port which the Arduino does not for this particular code as it's serial port is connecting to the PC.
I am using a low frequency Seeedstudio RDM630 reader module which is functionally the same as the ID-12.
NOTE for ease of transfer I have retained the Arduino format of
setup()
loop()
so my mbed code is
main()
while(1)
setup();
loop();
I would really appreciate some notes on what is wrong with my C code.
Thanks
Tim
Output 1
edited to remove a note about my code being here as I was unable to copy it in until I closed the compiler, reopened the program and copied it again.
sorry I had to edit it again. My first two output files were from the same tag.
Output 2 (second tag)
Readable: 1
bytesRead: 0
Tag READ: 33
tempByte: 3
bytesRead: 2
Tag READ: 42
tempByte: B
bytesRead: 4
Tag READ: 30
tempByte: 0
bytesRead: 6
Tag READ: 30
tempByte: 0
bytesRead: 8
Tag READ: 33
tempByte: 3
bytesRead: A
Tag READ: 34
tempByte: 4
Tag Value: 10007F90
Checksum: 0
--passed--Readable: 1
Readable: 1
Readable: 1
Readable: 1
Readable: 1
Readable: 1
Readable: 1
Output 3 (3rd tag)
Readable: 1
bytesRead: 0
Tag READ: 32
tempByte: 2
bytesRead: 2
Tag READ: 41
tempByte: A
bytesRead: 4
Tag READ: 30
tempByte: 0
bytesRead: 6
Tag READ: 30
tempByte: 0
bytesRead: 8
Tag READ: 35
tempByte: 5
bytesRead: A
Tag READ: 45
tempByte: E
Tag Value: 10007F90
Checksum: 0
Readable: 1
Readable: 1
Readable: 1
Readable: 1
Readable: 1
Readable: 1
edited to add program file - not sure why it wouldn't go before but I think it was a full serial buffer.
//* RFID Routines
//* Read RFID Tag
//* This code is from the book Practical Arduino by Jonathon Oxer and Hugh Blemings *
//* Other than as noted, I have reproduced it as written and with the authors *
//* comments and explanations *
//* It absolutely works as written in the Arduino. I need help converting to "C" *
//* The letters after the // are for me to track brackets eg //a-> open //a<- close
void loop()
{//a->
pc.baud(9600);
RFID.baud(9600);
int val = 0; // this should hold the character read from the reader
int checksum = 0; // this is checked against a calculated checksum
int bytesRead = 0; // counter if number of bytes read (2 characters per)
int tempByte = 0; // storage for character retreived
int tagBytes[6]; // or 12 characters. 5 bytes is tag value 1 is for checksum
int tagValue[11]; // the actual tag information +1 for adding null at string end
led2=1;
while(1)
{//b->
if (RFID.readable())
{//->c
pc.printf("Readable: %X\n\r", RFID.readable());
led3=1;
led1=0;
val = RFID.getc();
if (val == 2)
{//->d
bytesRead = 0;
for (bytesRead = 0; bytesRead < 12; bytesRead++)
{//-e
val = RFID.getc();
pc.printf("bytesRead: %X\n\r", bytesRead);
pc.printf("Tag READ: %X\n\r", val);
// In case the rfid module ever gets into a confused state, such as sending part
// of a sequence of tag values while the program was busy elsewhere, it checks
// each value to see whether it's a header or stop byte
if ((val == 0x0D) || (val == 0x0A) || (val == 0x03) || (val == 0x02))
{//f->
led2=0;
break;
}//f<-
// We store the tag ID in two different formats for convenience later in the program.
// The first format is as a series of raw values stored in a character array, with only the
// actual tag ID itself stored. We don't want to include the checksum, so the program
// only appends the first 10 characters into elements 0 through 9 in the tagValue array.
if (bytesRead < 10)
{//f->
tagValue[bytesRead] = val;
}//f<-
// The second value requires some processing and then stores each value as a separate
// element in an array of bytes, so the program does some ASCII/HEX conversion to each
// value.
if ((val >= '0') && (val <= '9'))
{//f->
val = val - '0';
}//f<-
else if ((val >= 'A') && (val <= 'F'))
{//f->
val = 10 + val - 'A';
}//f<-
// A byte is a total of 8 bits and can hold a value from 0 to decimal 255, while a hex
// digit is a 4 bit value (half a byte) from 0 to F. We can, therefore store two hex
// digits in each byte as a pair of 4-bit values.
// The code first checks if it's dealing with the second hex digit of a pair. If it
// is, the following comparison will be true.
if (bytesRead & 1 == 1)
{//f->
// This part of the code then deals with the second of a pair of hex digits. It makes
// space for this digit in the current byte using a bitwise operator to shift the
// existing 4 bits in that byte by 4 bits to the left leaving space for the second
// 4 bits to be set using the value in bytesRead.
tagBytes[bytesRead >> 1] = (val | (tempByte << 4));
// It then checks if it has reached the checksum byte, and if so calculates the checksum
// using an XOR operation
if (bytesRead >> 1 != 5)
{//g->
checksum ^= tagBytes[bytesRead >> 1];
pc.printf("Checksum just after XOR %X\n\r", checksum);
};//g<-
// This part of the code then deals with the first of a pair of hex digits by simply
// putting the value directly into a variable. This value will then be shifted 4 bits to
// the left on the next loop through by the code above.
}//f<-
else
{//f->
tempByte = val;
pc.printf("tempByte: %X\n\r", tempByte);
};//f<-
// The program them increments the counter that tracks how many bytes have been read and
// reaches the end of the loop, going back to the start to check if it has finished reading
// all the digits yet.
bytesRead++;
}//e<-
// The program checks if 12 bytes have been read, indicating that it has a complete read and
// can move on to comparing the acquired value with its list of authorized tags.
if (bytesRead == 12)
{//e->
led4=1;
tagValue[10] = '\0';
pc.printf("Tag Value: %X\n\r", tagValue);
pc.printf("Checksum: %X\n\r", (tagBytes[5]));
pc.printf(tagBytes[5] == checksum ? "--passed--":"--error--");
}//e<-
}//d<-
}//c<-
}//b<-
}//a<-
{//a->
pc.printf("mbed Serial Terminal \n\r");
wait(1);
setup();
loop();
}//a<-
Hi:
so my mbed code is
main() while(1) { setup(); loop(); }I would really appreciate some notes on what is wrong with my C code.
Thanks
Tim
Output 1
Output 3 (3rd tag)
//************************************************************************************** //* RFID Routines //************************************************************************************** //* Read RFID Tag //************************************************************************************** //************************************************************************************** //* This code is from the book Practical Arduino by Jonathon Oxer and Hugh Blemings * //* Other than as noted, I have reproduced it as written and with the authors * //* comments and explanations * //* It absolutely works as written in the Arduino. I need help converting to "C" * //************************************************************************************** //* The letters after the // are for me to track brackets eg //a-> open //a<- close void loop() {//a-> pc.baud(9600); RFID.baud(9600); int val = 0; // this should hold the character read from the reader int checksum = 0; // this is checked against a calculated checksum int bytesRead = 0; // counter if number of bytes read (2 characters per) int tempByte = 0; // storage for character retreived int tagBytes[6]; // or 12 characters. 5 bytes is tag value 1 is for checksum int tagValue[11]; // the actual tag information +1 for adding null at string end led2=1; while(1) {//b-> if (RFID.readable()) {//->c pc.printf("Readable: %X\n\r", RFID.readable()); led3=1; led1=0; val = RFID.getc(); if (val == 2) {//->d bytesRead = 0; for (bytesRead = 0; bytesRead < 12; bytesRead++) {//-e val = RFID.getc(); pc.printf("bytesRead: %X\n\r", bytesRead); pc.printf("Tag READ: %X\n\r", val); // In case the rfid module ever gets into a confused state, such as sending part // of a sequence of tag values while the program was busy elsewhere, it checks // each value to see whether it's a header or stop byte if ((val == 0x0D) || (val == 0x0A) || (val == 0x03) || (val == 0x02)) {//f-> led2=0; break; }//f<- // We store the tag ID in two different formats for convenience later in the program. // The first format is as a series of raw values stored in a character array, with only the // actual tag ID itself stored. We don't want to include the checksum, so the program // only appends the first 10 characters into elements 0 through 9 in the tagValue array. if (bytesRead < 10) {//f-> tagValue[bytesRead] = val; }//f<- // The second value requires some processing and then stores each value as a separate // element in an array of bytes, so the program does some ASCII/HEX conversion to each // value. if ((val >= '0') && (val <= '9')) {//f-> val = val - '0'; }//f<- else if ((val >= 'A') && (val <= 'F')) {//f-> val = 10 + val - 'A'; }//f<- // A byte is a total of 8 bits and can hold a value from 0 to decimal 255, while a hex // digit is a 4 bit value (half a byte) from 0 to F. We can, therefore store two hex // digits in each byte as a pair of 4-bit values. // // The code first checks if it's dealing with the second hex digit of a pair. If it // is, the following comparison will be true. if (bytesRead & 1 == 1) {//f-> // This part of the code then deals with the second of a pair of hex digits. It makes // space for this digit in the current byte using a bitwise operator to shift the // existing 4 bits in that byte by 4 bits to the left leaving space for the second // 4 bits to be set using the value in bytesRead. tagBytes[bytesRead >> 1] = (val | (tempByte << 4)); // It then checks if it has reached the checksum byte, and if so calculates the checksum // using an XOR operation if (bytesRead >> 1 != 5) {//g-> checksum ^= tagBytes[bytesRead >> 1]; pc.printf("Checksum just after XOR %X\n\r", checksum); };//g<- // This part of the code then deals with the first of a pair of hex digits by simply // putting the value directly into a variable. This value will then be shifted 4 bits to // the left on the next loop through by the code above. }//f<- else {//f-> tempByte = val; pc.printf("tempByte: %X\n\r", tempByte); };//f<- // The program them increments the counter that tracks how many bytes have been read and // reaches the end of the loop, going back to the start to check if it has finished reading // all the digits yet. bytesRead++; }//e<- // The program checks if 12 bytes have been read, indicating that it has a complete read and // can move on to comparing the acquired value with its list of authorized tags. if (bytesRead == 12) {//e-> led4=1; tagValue[10] = '\0'; pc.printf("Tag Value: %X\n\r", tagValue); pc.printf("Checksum: %X\n\r", (tagBytes[5])); pc.printf(tagBytes[5] == checksum ? "--passed--":"--error--"); }//e<- }//d<- }//c<- }//b<- }//a<- // int main() {//a-> pc.printf("mbed Serial Terminal \n\r"); wait(1); setup(); loop(); }//a<-
