is there a list of which io resources are used by the existing api, and which are available for the user.
case in point: i need to be able to access counter/timers for using the capture pins to measure the time between blade tips on a row of blades in a turbine, to determine if there is vibration.
also, if using the above, how does one add the appropriate interrupt handlers.
