Markos, it's a long time since I did this but from memory most AC motors tend to work synchronously with the mains supply frequency. They can however loose sync and resync for example when starting and also if the load is too great. So sometimes you can slow the motor down by a method that induces 'slip' by reducing the power supplied as you are doing, but it is easy for the motor to stall, not start or vary in speed with the load fluctuations.
Some AC motors with a stator coil can be speed controlled by varying the current through this winding.
Have you tried your circuit with a lamp of similar current rating as your motor? If your software/hadware is not working this will show up with the lamp brightness fluctuating, but if OK then your motor is not sutable for this method of control and really requires a variable frequency drive.
If you want to post more details of the motor type and describe how the results are not consistant, this may help further discussion.
I just recently pick up mbed and learn the programing lanague involve for my school final year project .
now the problem is that , I cant seem to use the detach the function Fert, a function to be called by ticker at 2 min interval . Itried using the sample for the detach given in the ticker library and it dosent seem to work .
Thank for helping ~ and sorry about the messy code
