I have been using the mbed for a couple months and observed the following problems with the USB flash drive and programming:
- The USB flash drive sometimes gets re-detected by the laptop (two laptops so far, vaio and lenovo) without any power reset. This happens both on windows and linux. This occurs more often when there are other high current electronics around, but also when nothing is around.
- I have 'broken' three mbeds, i.e. at some point I could no longer put any files into the flash drive. In the flash drive, I could see some files with long invalid names (symbols) and when trying to write on it, there is an I/O error. This has happened with three different laptops running both windows and linux. After some tests, I observed that (so far) this happened only when the mbed is being flashed or when the usb is unplugged/plugged while sharing a ground with a power supply that is on. This has happened with two different power supplies (one 12V and one 24V). Now I'm very careful to turn off the power supply before flashing the mbed or unplugging/plugging usb and so far, this seems to get rid of this problem.
Has anyone encountered any or both of these problems? Any input would be greatly appreciated, as the mbed has enabled us to have super fast development and I'd really like to continue using it.
Many thanks in advance!
Hello, I have been using the mbed for a couple months and observed the following problems with the USB flash drive and programming:
