pointers to the heap.
27 Oct 2011
I wrote the following program to see what happens when pointers to the heap are created:
class MyTest
    public:
        char someData[0xFF];
MyTest* test(void);
    MyTest* B1;
    MyTest* B2;
    B1 = test();
    B2 = test();
    printf("Address of B1 is: %x\r\n", B1);
    printf("Address of B2 is: %x\r\n", B2);
    while(1)
MyTest* test(void)
    return new MyTest();
The result of the program is:
Address of B1 is: 10000260
Address of B2 is: 10000368
It seems like B1 and B2 are placed directly after each other on the heap. One would expect that if the heap gets 'cleaned up', and the location of the objects are changed during this process ,the pointers will point to the wrong memory locations. This is not the case however. Does the processor use a hardware lookup table to get the memory pointed to by B1 and B2? i.e. are the addresses returned by the program virtual addresses?
27 Oct 2011
What do you mean by "cleaned up"? And why would object locations change all of a sudden?
27 Oct 2011
Whith "cleaned up" I mean heapsort: http://en.wikipedia.org/wiki/Heapsort. During this heapsort the location of the objects are changed.
