How do I expand the number of digital I/O pins?
29 May 2011
Mbed Community
How do I increase the number of Digital I/O pins available.
Kind Regards David
29 May 2011
Hi David,
Any of the mbed LPC1768 pins p5 - p30 can be used as digital I/O (i.e. 26 lines).
If this is not enough you can use things like I2C port expanders. You can connect a number of these chips to the 2 pin I2C bus, with each chip giving you control of usually 8 or 16 I/O lines. There are a number listed in the cookbook under "Interfaces and Drivers".
One example would be:
But see the Cookbook for a whole selection.
Simon
