Does SDFileSystem and SDHCFileSystem support r+ (and w+) for opening a file for random read/writes? I need to seek all over the file to do database operations, so append isn't going to work for me.
Here is my code that is failing at the first fopen. Each time the program run it is supposed to swap the two ints in order in the file. Similar code works in cygwin, doesn't work in mbed.
#include <mbed.h>
#include "SDHCFileSystem.h"
#define DEBUG_LINE printf("%d\n", __LINE__);
Serial console(USBTX, USBRX);
void exitmsg(const char* message)
fprintf(stderr, "%s\n", message);
exit(1);
SDFileSystem sd(p5, p6, p7, p8, "sd"); // mosi, miso, sclk, cs, mount point
console.baud(921600); // mbed to pc usb serial supports: 110, 300, 600, 1200, 2400, 4800, 9600, 14400, 19200, 38400, 57600, 115200, 230400, 460800, 921600
console.puts(
"\x1b[2J\x1b[H"
__FILE__ "\r\n"
__DATE__ " " __TIME__ "\r\n"
"\r\n");
DEBUG_LINE
FILE* fp = fopen("/sd/ttt.bin", "r+");
DEBUG_LINE
if (fp == 0)
DEBUG_LINE
fp = fopen("/sd/ttt.bin", "w+");
DEBUG_LINE
fseek(fp, 0, SEEK_END);
int size = ftell(fp);
printf("size = %d\n", size);
int data1=0;
int data2=0;
if (size == 0)
data1=123;
if (fwrite(&data1, sizeof(data1), 1, fp) != 1)
exitmsg("failed to write");
data2=321;
if (fwrite(&data2, sizeof(data2), 1, fp) != 1)
data1 = 0;
data2 = 0;
fseek(fp, 0, SEEK_SET);
if (fread(&data1, sizeof(data1), 1, fp) != 1)
exitmsg("failed to read");
if (fread(&data2, sizeof(data2), 1, fp) != 1)
printf("read: %d %d\n", data1, data2);
printf("wrote: %d %d\n", data2, data1);
fclose(fp);
#include <mbed.h> #include "SDHCFileSystem.h" #define DEBUG_LINE printf("%d\n", __LINE__); Serial console(USBTX, USBRX); void exitmsg(const char* message) { fprintf(stderr, "%s\n", message); exit(1); } int main() { SDFileSystem sd(p5, p6, p7, p8, "sd"); // mosi, miso, sclk, cs, mount point console.baud(921600); // mbed to pc usb serial supports: 110, 300, 600, 1200, 2400, 4800, 9600, 14400, 19200, 38400, 57600, 115200, 230400, 460800, 921600 console.puts( "\x1b[2J\x1b[H" __FILE__ "\r\n" __DATE__ " " __TIME__ "\r\n" "\r\n"); DEBUG_LINE FILE* fp = fopen("/sd/ttt.bin", "r+"); DEBUG_LINE if (fp == 0) { DEBUG_LINE fp = fopen("/sd/ttt.bin", "w+"); } DEBUG_LINE fseek(fp, 0, SEEK_END); int size = ftell(fp); printf("size = %d\n", size); int data1=0; int data2=0; if (size == 0) { data1=123; if (fwrite(&data1, sizeof(data1), 1, fp) != 1) exitmsg("failed to write"); data2=321; if (fwrite(&data2, sizeof(data2), 1, fp) != 1) exitmsg("failed to write"); } data1 = 0; data2 = 0; fseek(fp, 0, SEEK_SET); if (fread(&data1, sizeof(data1), 1, fp) != 1) exitmsg("failed to read"); if (fread(&data2, sizeof(data2), 1, fp) != 1) exitmsg("failed to read"); fseek(fp, 0, SEEK_SET); if (fwrite(&data2, sizeof(data2), 1, fp) != 1) exitmsg("failed to write"); if (fwrite(&data1, sizeof(data1), 1, fp) != 1) exitmsg("failed to write"); printf("read: %d %d\n", data1, data2); printf("wrote: %d %d\n", data2, data1); fclose(fp); }
