newbe syntax issues
25 Nov 2015
Error: Expression must have pointer-to-object type
I cant fix this error...
in Main
volatile int tx1_in, tx1_out, rx1_in, rx1_out;
char tx1_buffer[400];
in the new module;
extern int tx1_in, tx1_out, rx1_in, rx1_out;
extern const int tx1_buffer, rx1_buffer;
tx1_buffer[tx1_in] = Tx1_byte;
Error: Expression must have pointer-to-object type in "Usart1.cpp", Line: 186, Col: 21
25 Nov 2015
ok, this worked,,
extern const int tx1_buffer[0], rx1_buffer[0];
but now it still fails on the same line.
Error: Expression must be a modifiable lvalue in "Usart1.cpp", Line: 183, Col: 10
25 Nov 2015
Please use <<code>> and <</code>> around your posted code to keep it readable.
The problem is that your declare the array as constant:
You are not allowed to assign a new value to a constant array. Error: Expression must be a modifiable lvalue in "Usart1.cpp", Says that lefthand side must be a variable and not a constant.
Try for main:
char rx1_buffer[400];
Try for module:
extern int tx1_buffer[], rx1_buffer[];
25 Nov 2015
thanks for the pointers,
the reference 0 was one problem, thanks for showing me, but also ' int ' was incorrect. since it is a char array,
adjusting to this fixed it, :)
extern char tx1_buffer[], rx1_buffer[];
thanks again :)
