Thanks for looking in on my problem...
ok, I think I have done it, now it compiles...
was it best to retain the project generated lib or run with the latest lib ?
I can roll it back, if you think it is best
otherwise,
but my previous problem still exists,
how can I get an interrupt if a serial port goes idle ?
should I start a new thread, ?
can I use something like this ?
int write (const uint8_t *buffer, int length, const event_callback_t &callback, int event=SERIAL_EVENT_TX_COMPLETE)
Begin asynchronous write using 8bit buffer.
int write (const uint16_t *buffer, int length, const event_callback_t &callback, int event=SERIAL_EVENT_TX_COMPLETE)
Begin asynchronous write using 16bit buffer.
Nick.
I am new to mbed :(
I was trying to detect a break on a serial stream using timer/timerout
not quite working , not sure why, reading reading...
I found this and had a look...
Erik Olieman :- The source code can be found here: http://developer.mbed.org/users/mbed_official/code/mbed-src/. The timer code is somewhere in targets/hal/freescale/[KLxx/KSDK]/us_ticker_api.c. And to answer it directly, The K64F uses four PIT timers for Timer/Ticker objects (Freescale MCUs aren't very efficient at implementing this, most NXP ones use a single timer for example), the KL46 uses two PIT timers and the LPTMR (PIT for Timer, LPTMR for ticker). From <https://developer.mbed.org/questions/7433/What-Timer-is-used/>
I don't really know my way around yet, I imported the library... not sure if that's a good thing or not...
now we don't compile...:(
Can I undo this ? or fix it ?
this is the error :
Error: "/extras/mbed_ba1f97679dad/TARGET_NUCLEO_F072RB/TOOLCHAIN_ARM_MICRO/stm32f072rb.sct", line 34 (column 9): Error: L6235E: More than one section matches selector - cannot all be FIRST/LAST.
