The usage notes for read() says:
Read the input voltage, represented as a float in the range [0.0, 1.0]
Is the range [0.0, 1.0] a percentage referenced to the max. voltage that can be applied to the pin?
Further for the value returned, is that a percentage too referenced to the max. voltage that can be applied to the pin?
Thanks
