Low power, wireless communication with sensors
20 Oct 2010
I would like to hang a sensor outsite my house, for example a temperature sensor, and I want it to sent its readings every 5 minutes to a mbed powered read station.
What is the best way to setup the wireless connection? I would like to power the sensors using a battery, but I do not want to change the battery every day, so it should be as low power as possible.
One solution I found is using XBee. Is that a good sollution or are there better ones?
20 Oct 2010
TI has some low-power RF solutions, might be worth a try.
20 Oct 2010
The TI/Chipcon CC1101 ultra low power 868 MHz chipset is available in an easy-to-use form from Seeed Studios as the RFbee - it's an Arduino-compatible AVR attached to the CC1101 via SPI - you could either patch into the SPI or use the AVR as is for the sensor. It saves a lot of time designing an antenna and matching circuit, and is also cheaper than other eval boards which only have the radio and not the AVR.
07 Nov 2010
Hello
I use small devices from http://www.hoperf.com/rf_fsk/rfm12.htm  called rfm12. They have a SPI Interface and are easy to use. In germany they will cost abot 5 € .
The RFM12B devices are 3.3 Volt devices
07 Nov 2010
user Dieter Brueggemann wrote:
Hello
07 Nov 2010
Hello
sorry, try it once more. My Ipad generates empty postings, here :-)
Please have a look at the Jeelabs page or look for Jennic wire less products.
best regards
Franz
