Hi:
Not being the strongest programmer in C, I often search for code examples for things that I want to do in order to see how others have implemented.
I often come across signed and unsigned variables and I can't seem to make use of the code on the mbed. I have had limited success in converting these and usually end up creating more problems with mixed data types than I can get myself out of.
Can I use u08, s08, u16 as written in functions, or do I need to set them as something else?
For example:
void sta013GetMP3Info(u16 *bitrate, u08 *sampFreq, u08 *mode)
u08 headL, headM, headH;
u08 mpegID, bitrateIndex, sampFreqIndex; This is a partial copy out of some MP3 code I am looking at that is using an STA013 decoder.
Can I write something at the beginning of my code that says U16 = unsigned 16 bit mbed variable and how is "unsigned 16 bit mbed variable" declared?
If there is documentation for this, please point me to it.
Tim
Hi:
For example:
void sta013GetMP3Info(u16 *bitrate, u08 *sampFreq, u08 *mode) { u08 headL, headM, headH; u08 mpegID, bitrateIndex, sampFreqIndex;This is a partial copy out of some MP3 code I am looking at that is using an STA013 decoder.Can I write something at the beginning of my code that says U16 = unsigned 16 bit mbed variable and how is "unsigned 16 bit mbed variable" declared?
Tim
