Is "mbed-export" required currently?
If you have updated version, please share with us.
Or, I appreciate if you can fix the "export" mechanism to include proper files.
I have following problem:
I tried exporting program to LPCXpresso(code_red) and found it was not including "mbed.h".
Then I found this topic and tried...
It works fine for some programs but it is not for any programs.
If the "mbed-export" lib is used in a complex program, it gives an error with following message.
code_red error message wrote:
"/Users/okano/dev/_lpcxpresso/test2/_program_name/mbed-export/Base.h:11:19: fatal error: cstdlib: No such file or directory"
It gives errors even if compiled by mbed-compiler.
(I remember that I've seen similar message when I start beta-test for collaboration environment.)
I'm trying to export my project to a licensed version of uVision4 and although the export process completes successfully providing a zip file, when I open with uVision4 and try to compile, I get the error, "error: #5: cannot open source input file "mbed.h": No such file or directory" I've tried importing other people's projects with the same issues. Compilation in the online compiler works well. I've even tried importing the latest mbed build with no success. Any ideas?
