Operating system
Development tools
Security and connectivity
Not familiar with VB, but some observations:
You have
SerialPort1.ReadLine() = "mbedhere"
That probably means the VB applications expects a newline/carriage return at the end of the string. Is mbed sending that?
Is
a valid way of doing string compares in VB? May have to use something like
String.compare(SerialPort1.ReadLine(),"mbedhere")
Sorry for answering my own thread (DUH) LOL I've just figured it out. There is a char at the end of the received readline so i've got the functionality i need now :) thanks for replying.
For anyone who will have this problem here is the code i've created, I've also fully commented it so you can see in your mind what happens.
Functionality: Search for response on every comport and keep comport open if correct response is received
mbed C++ Example of the automated response This code is in my repository bellow
//Connection to device atempted if (strcmp("DRCmbed", pFields[0]) == 0) { pc.printf("mbeddevice\r\n");//Validate correct port query (For Ext Application Port Chcking) }
VB.NET Example of serialport scanning for automated response
Dim com As String = "COM" //Serialport names are written in strings so all we need to do is add an integer to it Dim validport As Boolean //Allows us to stop scanning as soon as we retreive a valid response on that port Dim check As System.Threading.Thread //Threading allows us to prevent lock up of an interface and also provides a quicker scan //Function at load up to scan for response from serialport Private Sub Form1_Load(sender As Object, e As System.EventArgs) Handles Me.Load CheckForIllegalCrossThreadCalls = False //We will be making illegal thread calls. At this point it does not matter check = New System.Threading.Thread(AddressOf readthread) //Lets configure a sub to run the thread check.Start() //Lets start the thread before anything else Dim idle_wait as integer = 50 //Wait idlers help in slowing things down for the mbed device or any other device for that matter SerialPort1.ReadTimeout = idle_wait //Give time for the mbed to respond For i = 0 To 256 //Every com port accounted for Try //Lets try the port to check if it exists or if it gives us the correct response If validport = True Then //This will stop scanning once the correct response is received msgbox("Serial Port Correct Response from: " + SerialPort1.PortName) //Visual feedback of correct port found Exit For //We will no longer need to be in this loop as we've found the correct com port so lets exit this routine End If SerialPort1.PortName = com + i.ToString //Change the com number through every fail of the try event SerialPort1.Open() //Lets try to open the port on every try event if it exists or not SerialPort1.WriteLine("DRCmbed") //Writes this to the com port and waits for a response System.Threading.Thread.Sleep(idle_wait) //allow time for thread to read reply Catch ex As Exception //Lets catch the exception of a faild response or no connection and handle the exception Try //Lets try to close the port if we are connected to a device but gives us an incorrect response SerialPort1.Close() //Closes the serial com port for the next iteration Catch ex1 As Exception //We dont need to handle this exception at all! End Try End Try Next //Loop to the next comport Exit Sub //Constantly read the open serialport for response (Responses are length -1) Public Sub readthread() Dim message //Lets create a dynamic response storage variable Do Until (validport = True) //If we have found the correct port then we dont need to do anything else! Try //Lets try this if the current com port is open message = SerialPort1.ReadLine.ToString //Store the response of the device If message.Substring(0, message.ToString.Length - 1) = "mbeddevice" Then //Check if the response equals: mbeddevice validport = True //If the response is correct then we've successfully validated which comport we should connect to End If Catch ex As Exception //No need to handle this exception at all! End Try Loop //Keep trying no matter what comport is open or closed End Sub
Updated many functions and bugs from the previous version. This program can emulate the keyboard and mouse on another computer using serial input [PC1-USB-MBED-USB-PC2] Control using serial input to keyboard/mouse output like a regular keyboard and mouse.
Last commit 14 Jun 2012 by . .
I've written a connection/rejection code for my windows application which should try to send my mbed a string and respond with a string but i'm running into a problem!
The mbed receives the string and sends its value back but my application does not wanna have it?
Here is my code for vb
Can anyone see what's wrong? because i really dont >.<
