Operating system
Development tools
Security and connectivity
There are lots of ways to solve this. For example:
<snip> int i;
int leds=0x00;
int score[8];
bool sw_detected[8];
Mosi Initialization device.format(16,0); 16 bits, clock idles low, data capture on rising edge pulse = 0; Initialize the latch signal device.write(0x0000); Write 16 bits of data to the SPI to clear the relay port pulse = 1; Latch the preceding data wait_us(1); Enforce a minimum inter-transfer interval
Clear the score array to all 0, clear the detect flags
for (i=0; i<8; i++) {
score[i] = 0;
sw_detected[i] = false;
leds = 0; reset led pattern
Test Switches
if (sw0) {
leds = leds | led0; If switch one, set bit for led number 1
Increment score, only once per switch activation,
need to debounce this..
if (! sw_detected[0]){
score[0] = score[0] + 10;
sw_detected[0] = true;
else {
sw_detected[0] = false;
<snip, same for led1..led6>
if (sw7) {
leds = leds | led7; If switch seven, set bit for led number 7
if (! sw_detected[7]){
score[7] = score[7] + 10;
sw_detected[7] = true;
else {
sw_detected[7] = false;
now display the led pattern for all active leds
pulse = 0;
device.write(leds);
pulse = 1;
wait_us(1);
Here is code for a simple pinball circuit.
8 switches control 8 lamps.
Ball hits switch 1 - lamp 1 lights up. Ball hits switch 2 - lamp 2 lights up.
How do I change this code to make the lamps light up MOMENTARILY?
At the moment when a switch is activated the corresponding lamp stays on until another switch is activated.
I want each lamp to light up only as long as the corresponding switch is depressed.
I would also like to add a scoring system where 10 points is stored each time a switch gets activated.
Here is the code so far:
Cheers David
