I got a strange error
19 Apr 2011
Hello mbed community.
I got a strange error from the compiler.( screen shot is attached ) Someone has a suggestion of the causes of this error?
Thank you in advance /media/uploads/affatatiej/error_compilador_mbed.jpg
19 Apr 2011
Hi Emanuel,
It basically means that a declaration is probably miss-formed, as it doesn't declare anything. So for example, something like the following would give that error:
int;
It is obviously unlikely that LPC17xx.h has an error like this, so you can then suspect it is something impacting it. If you look at line 795 of LPC17xx.h, it is:
__IO uint32_t TEST;
So that suggests to me that somewhere before you include LPC17xx.h somewhere, there is some code that looks like:
#define TEST
or alike. i.e. defining TEST to be nothing, which impacts the definition in LPC17xx.h as it replaces the structure element name with nothing, which gives that error. If it is not that, it is probably something similar.
Hope that helps,
19 Apr 2011
Thanks Simon.
You were right.
One million thanks.
