How to debug idDHTLib?
28 Jan 2014
Hi, I have just published my test code http://mbed.org/users/Njbuch/code/NewDHT11Test/
This code uses the idDHTLib but the output is not right. Kamil (author of idDHTLib) thinks there might be a problem with a pull-up resistor but I dont have a clue... I think there is missing some bits.
The old DHTLib often resulted in checksum error, and I have not been able to find the error in this one as well.
Output from test-program (endless loop)
Status is 0
Temperature is -3.00 C
Humidity is -3.00
Status is 0
Humidity is -3.00
Do you have any ideas what can be wrong here?
28 Jan 2014
Niels,
This may help. At least you know the history reading from the DHT devices.
http://mbed.org/questions/623/DHT11-checksum-error/
...kevin
29 Jan 2014
Thanks Kevin, I have actually been trying to grasp you post from that thread, without luck. I still think there is an error somewhere, and now the question is: where?
29 Jan 2014
Since only odd returned numbers from the DHT generate checksum errors (23, 25, 27, etc) and even returned numbers do not, I spent a little time looking at the code. From what I could tell, the very first bit read from the DHT gets missed. I thought I could see where the the driver's author then shifted the data by one bit to try to compensate for the missed bit. I could be wrong, but that's what I thought I saw.
...kevin
