I´ve been working on a product based on both LPC chips. Looking though the forums, i´ve seen that the code generated in my prototipes (using both mbed boards) will work directly when i program the chips in the final board. But what i don´t have so clear, is what programmer to use. I´ve seen that the mbed itself can work as programmer but i would like to use a more..."pro" solution. So does any one have a good reference (and cheap, please!)
By the way, i don´t know if other users had the same experience, but is f&%&ing fast to work with this... i´m using both models just because it makes easier the programming and the final boards, and i can improve upgrades easier (one lpc will take care of lcd, leds, buttons...and the other one will take care of coms, meassurements...). Faster, easier and cheaper than arduino chips. The only lack, is that there is no off-line compiler, but just because i don´t have always access to internet signal.
Hi, I´ve been working on a product based on both LPC chips. Looking though the forums, i´ve seen that the code generated in my prototipes (using both mbed boards) will work directly when i program the chips in the final board. But what i don´t have so clear, is what programmer to use. I´ve seen that the mbed itself can work as programmer but i would like to use a more..."pro" solution. So does any one have a good reference (and cheap, please!)
