LPCxpresso 1769 Ethernet has anyone got it working ?
18 Jul 2012
LPCxpresso is a cheaper alternative to an Mbed in a semi permanent project. Has anyone got the Lan8720 PHY to work with it ?
21 Jul 2012
Never-mind I finally got an espresso and have got the new EthernetInterface working with the lan8720 Phy on the expresso. A BIG thankyou to Emilio Monti for pointing me in the right direction.
21 Jul 2012
works perfectly ! Just checked by uploading a point to nimbits (no serial debug line hooked up to the uart atm) all working perfectly as expected. I based my hacks on an older library revision so i will update and fork. Thanks again Emilio
21 Jul 2012
Mav, do you have a link to this fork/library? I have my board on order from mouser.
21 Jul 2012
I haven't published it yet as I kinda just hacked around the TCPHelloWorld example and libs. I will pull the latest libs make the changes and publish it. there are some accidental commits that i cant seem to delete from this one. but all works
21 Jul 2012
