Problems with DS18S20 ! What ist wrong?
09 May 2012
Hi my Name is Florian, Need Help with my Mbed LPC1768 because I have some Problems with the DS18S20.
I connect the PIN1(GND) to GND, PIN2(DQ) to PIN25, PIN3(VDD) to PIN VU and between DQ
and VDD i connect a 4,7KOhm Resistor.
When i connect all this with my Mbed, than the mbed get off!!!
Waht´s wrong??? some of the parts damaged???
Sorry for my bad english :-)
Thank you for all answer!
Florian
09 May 2012
My understanding is Pin VU is +5V only when the mbed is plugged into the computer USB port. Is that the issue, i.e. only works when USB plugged in?
09 May 2012
09 May 2012
Hi!
I connect like this and it works:
1 -> GND
2 (DQ) -> p23 and Pullup(4k7) -> 3V3(pin40)
3 -> 3V3(pin40)
Charly
09 May 2012
Thank you for help guy's
I have change GND ans VDD
But my New Problem is that i become an Adress but the
"Need to use a Ds18s20 or Ds18b20 for correct results"
Is my ds18s20 dead?
04 Jun 2012
/media/uploads/GMawston/_scaled_imag0099.jpg
This is how I have got the sensor wired up. Makes use of the following project:
http://mbed.org/users/feabhas/notebook/ds18b20-temperature-sensor/?page=1#comment-230
I hope this helps from a visual perspective but to explain a little more:
1 - Black - GND 2 - Yellow - Pin5 3 - Red - VU
