Adjustable bigger sensitivity: Effactively filter noise from bigger signal and avoid false trigger
20 automatic measurements
Cursor measurements: Manual, Track and Auto Measure modes
10 waveforms, 10 setups, BMP and CSV storage
Math functions:+, -, x, FFT, Invert
Special digital filter and waveform recorder
Built-in hardware frequency counter
Standard interface: USB Device, USB Host, RS-232
Standard configuration: PassIFail test, effectively avoid electromagnetic interference by using photoelectricity-isolation
Multi-language user interface, built-in help system
Direct print to PictBridge compatible printers via USB Device interface.
Thanks.
Has anyone used the Rigol DS1052E 50MHz Digital Oscilloscope? http://www.tequipment.net/RigolDS1052E.html
It's a 2 channel scope for only $399US. It gets really good reviews online and the price is really good too.
I'm thinking about buying it and was wondering if anyone has it and could share some pros/cons...
Features:
* 1 GSa/s maximum real-time sample rate, 25 GSa/s maximum equivalent-time sample rate
* 1Mpts long Memory Depth
* 100 MHz, 50 MHz Bandwidths
* Ultra compact design: 303mm x 154mm x 133mm (WxHxD)
* 64 k TFT color LCD, bright and vivid waveform display
* Advanced trigger modes: Edge, Video, Pulse Width, Slope, Alternate
* Adjustable bigger sensitivity: Effactively filter noise from bigger signal and avoid false trigger
* 20 automatic measurements
* Cursor measurements: Manual, Track and Auto Measure modes
* 10 waveforms, 10 setups, BMP and CSV storage
* Math functions:+, -, x, FFT, Invert
* Special digital filter and waveform recorder
* Built-in hardware frequency counter
* Standard interface: USB Device, USB Host, RS-232
* Standard configuration: PassIFail test, effectively avoid electromagnetic interference by using photoelectricity-isolation
* Multi-language user interface, built-in help system
* Direct print to PictBridge compatible printers via USB Device interface.
Thanks.
Check out EEVBlog.com. Dave does a full review and a teardown of it. Furthermore, you can do a certain mod that increases the bandwidth of the scope. Have a look for it. It's an excellent scope for the price!
Dear Kevin,
We are Hantek agent in Europe and have a lot of DSO5000 series that seem like Rigol scopes.
Please visit our website (http://elec3i.com) and get a special discount if you are an eevblog user !!!
Cheers,
Pascal
Dear Kevin,
Cheers,
Pascal
You can't do that anymore , they upgraded the firmware, unless you find the ones with the old firmware. Cheap (read: poor) students can use the ones at their school lab.
<<quote igor_m>>
<</quote>>
you can still get your hands on one with the initial firmware as you said. And I think you can also downgrade the firmware. I don't know much more than that as I do not have one of these.
Cookie Policy
Access Warning
Features:
Thanks.
