Dual High Side Driver with Current Sense
16 Nov 2016
The MSK6000RH is a radiation hardened dual 5A radiation hardened high side driver switch module with current sensing output. It is capable of switching up to 5 A maximum current independently controlled by the 5 V logic. Its sensing topology provides a very wide input common mode range, while maintaining highly accurate current sensing capability. (Our blog http://www.kynix.com/Blog/ provides more information about switch modules)
The gain of the current sense amplifier is programmed via a single user selectable load resistor. High PSRR and CMRR provide reliable current sense data in a variety of applications. This flexibility makes the MSK6000RH suitable for many demanding load control and monitoring applications. The MSK6000RH is available in a hermetic 26 pin flat pack with straight leads. The MSK6000RH will soon be available to three screening levels: MIL-PRF-38534 Class “K” or Class “H” with an operating range of -55°C to +125°C, or Industrial with a operating range of -40°C to +85°C. The MSK6000RH is an excellent choice for high reliability applications that require accuracy, a wide dynamic range, high circuit density, and maximized efficiency.
Features
Manufactured using Linear Technology RH 6105 Dice Radiation Hardened to 100Krad(Si) (Method 1019 Condition A) 100V RAD HARD MOSFETs Dual Configuration Low Profile Surface Mount Flatpack 12V to 44V Input Voltage Range 5V to 36V VCC Supply Range 5A Max. Rating for Rad Hard Switches Contact MSK for MIL-PRF-38534 Qualification Status
