No schematic that I can find, I've asked on the manufacturers forum.
Looking at the board there isn't a lot on there. A 5V to 3V (or maybe 3.3V) regulator for the USB power input which will be shut down when running off a battery, a couple of diodes, one will be combining the two power sources, not sure what the others are for.
A single transistor and then a range of Rs and Cs.
It could be pullup/down resistors, two 47k or four 100k resistors would account for the current.
Once thing I can be sure of, there is no over current protection on the LDO, I blew it up by shorting something while poking around on the board with a meter.
Still runs fine off a battery so hopefully all that is needed is a new regulator.
Further to this question: http://mbed.org/questions/4524/mBuino-not-waking-up-from-sleep/ I have checked the power consumption of the mBuino in various modes.
All power numbers are running from 3.0V on the battery input terminals with all LEDs off and no external load connected.
Battery life is assuming a standard CR3032 coin battery.
To enter power down mode use (2):
void myPowerDown() { LPC_PMU->PCON = 0x2; SCB->SCR |= SCB_SCR_SLEEPDEEP_Msk; LPC_SYSCON->PDAWAKECFG &= 0xFFFFF800; __WFI(); }(1) Actual life will be less than this since capacity drops with current draws over 1mA,
(2) This skips a number of the steps the user manual lists but same steps are skipped by the library code for deep sleep. I've not seen any problems but your mileage may vary.
