I've connected up a Spark Fun colour LCD breakout board (from here: http://proto-pic.co.uk/products/Color-LCD-%252d-Breakout-Board.html), the PCB itself is red and the display has a silver elliptical sticker with "GE" on it. I've tried it with the test program here: http://mbed.org/cookbook/Nokia-LCD. It seems to work, once I set the display type to "LCD6610", but it has a number of problems. The first is a two pixel wide vertical white bar on the far left of the display and a similar blue bar along the bottom of the display. The sine wave is rendered using black (0x000000), but around a third of the pixels are rendered red. I added a section to the program that waits five seconds and then clears the display (to 0x0000FF), and this results in a green bar every third column of the display. I can't find much information, but I would guess this is because of either bad configuration at reset, or invalid formatting for the colour data. I've tweaked the program and tested the connections on the board without any success. Any ideas, anyone?
