Suggestion: Build code or SVN code
When working on embedded HW it is always easy to loose track of what exactly is running. A common trick is to include the SVN rev number, timestamp or some other counter.
Right now the system seems to track the build number. Is this exposed; so we can do something like
printf("Started (Build #" __BUILD_NO__ " - compiled " __DATE__ "\r\n");
Thanks,
Dw.
28 Oct 2010
Another vote for this. It would be very handy to be able to check the build number!
28 Oct 2010
Hi Dirk, Ian,
We don't support this, but we could do something like it. Would a timestamp be acceptable for you (e.g. a UNIX timestamp)?
Cheers,
Simon
28 Oct 2010
Its workable.
i'd like to be able to printf it so that i can identify a 'build number' in the final system.
23 Jan 2011
You can already printf the TIME macro (or variable?):
    printf("******** [%s] *********\n",__TIME__);
23 Jan 2011
Excellent point Hendrik,
See more: http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.dui0041c/Babbacdb.html
We will still look at including our own data in the build in the future.
Dan
03 Jul 2014
Any actions or updates related to this ??
03 Jul 2014
@Mika,
there're 2 macros, one is MBED_BUILD_TIMESTAMP and revision macro MBED_LIBRARY_VERSION.
0xc0170
03 Jul 2014
Did not work as I tried it in this way: Software static char swversion[31] = "MBED_BUILD_TIMESTAMP ";
Any example available ?
03 Jul 2014
Solved: add this into the main() sprintf(swversion,"Build: %f", MBED_BUILD_TIMESTAMP); TODO format more readable year, month, day, hours, minutes, seconds
03 Jul 2014
Quick format: time_t temp; struct tm *timeptr; temp = MBED_BUILD_TIMESTAMP; timeptr = localtime(&temp); strftime(swversion,sizeof(swversion),"Build %A-%b-%d %r", timeptr);
