Hy,
First excuse me for my english i am french.
I want use the PwmOut with the mbed LPC1768, i use this Pwm to control 4 servomotors, i receive a trame from a remote with the position of my servomotors (it's a remote for a guided airplane).
But when i send a pulsewidth < 1 ms the pwm doesn't run.
The comportement of the pwm is binary, in fact when the pulsewidth is 2 ms so the servo run and it goes to right but if the pulsewidth is < 2ms the servos go to left directly(until the maximum).
I send the pulsewidth with a algo and the result of the algo it's between 0,9ms and 2ms the extreme values for a sermotor.
For me, the problem is the pwm but i don't know how solve this problem, but i don't want use the servo library.
I give my code to help understand.
Thanks.
#include "Servo.h"
Serial telecommande(p13, p14); //liaison serie mbed <-> module telecommande
Serial pc(USBTX, USBRX);// liaison serie pc <-> mbed
PwmOut gauche_hori(p26);//the pwm for my 4 servomotors
PwmOut gauche_vert(p22);
PwmOut droite_hori(p23);
PwmOut droite_vert(p24);
/*After this variables are to the remote and they aren't important for the resolution of my problem*/
int tab[6],msb,lsb;
char a;
float valeur_max[4]={924,1100,1100,956};//max values from the manettes of the the remote
float valeur_min[4]={270,172,176,76};//min values from the manettes of the remote
float positionzero[4]={327,464,462,440};//the central position the manettes of the remote
/*it's the fontion to the interruption when i receive the trame from the remote, i work this trame to extract
the position for my different servo and i stock this position in a table */
void reception()
a=telecommande.getc();
if( a=='$')
if(a=='T')
pc.printf("trame ");
for(int i=0;i<=5;i++)
{ msb= telecommande.getc();
lsb=telecommande.getc();
tab[i]=msb*256+lsb;
gauche_hori.period(0.022);
gauche_vert.period(0.022);
droite_hori.period(0.022);
droite_vert.period(0.022);
pc.baud(9600);
telecommande.baud(115200);
telecommande.attach(&reception) ;
while(true)
/*i choose the pulsewidth with a little algo it's a rule of three */
droite_vert.pulsewidth_ms(float((1+(((tab[0]-positionzero[0])*0.55)/positionzero[0]))));
droite_hori.pulsewidth_ms(float((1.5+(((tab[1]-positionzero[1])*0.55)/positionzero[1]))));
gauche_vert.pulsewidth_ms(float((1.25+(((tab[2]-positionzero[2])*0.55)/positionzero[2]))));
gauche_hori.pulsewidth_ms(float((1.45+(((tab[3]-positionzero[3])*0.55)/positionzero[3]))));
Hy,
Thanks.
