Feature request and bug report
11 Sep 2012
Hello mbed team,
Feature request, please add
    int set_broadcast(bool bBroadcast = true)
    {   int val = (bBroadcast != 0);
        return lwip_setsockopt(_sock_fd,SOL_SOCKET,SO_BROADCAST,&val,sizeof(val));
to UDPSocket
Also, bug ?
Endpoint ep;
ep.set_address("255.255.255.255",0);
set_address fails with a return value of -1, but
class Endpoint2 : public Endpoint
public:
    int set_address(uint32_t ip, uint16_t port)
        reset_address();
        _remoteHost.sin_addr.s_addr = htonl(ip);
        _remoteHost.sin_family = AF_INET;
        _remoteHost.sin_port = htons(port);
        return 0;
Endpoint2 ep
ep.set_address(0xFFFFFFF,0);
works as expected when used with UDPSocket.set_broadcast()
Thanks
11 Sep 2012
Logged, thanks!
06 Aug 2018
Hello mbed team,
Assertion will occur if the following code is executed. It seems to be a problem to use PC5 for AD input. Just creating an instance does not matter. An assertion is generated when AD conversion is executed using that instance.
Assert message are: ++ MbedOS Error Info ++ Error Status: 0x80010130 Code: 304 Module: 1 Error Message: pinmap not found for peripheral
Board is: Nucleo F302R8
Code is: AnalogIn ADC_foo(PC_5); var = ADC_foo.read_u16();
