I use Mbed LPC1768.
Today i fall on a bug with DigitalOut array when you try to write out of range.
If you initialize an array in first you dont have the same result with an array in last.
Like you can see beelow i had try on lots of compilers and the results change again.
array first
DigitalOut leds[] = {LED1, LED2};
DigitalOut out(p5);
leds[-1] = 1;
leds[0] = 1;
leds[2] = 1;
leds[1] = 1;
Mbed OS Simulator -> LED1 and LED2 are ON
Mbed Online Compiler with mbed 2 -> LED1 and LED2 are ON
Mbed Online Compiler with mbedOS 5.9.7 -> LED1 and LED2 are OFF
Mbed CLI Compiler with GCC_ARM and mbedOS 5.9.7-> LED1 and LED2 are OFF
Mbed Studio Compiler with ARMC6 and mbedOS 5.9.7 -> LED1 blink and LED2 OFF
array last
DigitalOut out(p5);
leds[-1] = 1;
leds[0] = 1;
leds[2] = 1;
leds[1] = 1;
Mbed Online Compiler with mbed 2 -> LED1 ON and after a little delay LED1 blink and LED2 OFF
Mbed Online Compiler with mbedOS 5.9.7 -> LED1 ON and LED2 OFF
I think Mbed CLI Compiler with GCC_ARM or ARMC6 give good results, isn't it?
But why these differences...?
Thanks for your help,
YSI
I use Mbed LPC1768.
array first
array last
I think Mbed CLI Compiler with GCC_ARM or ARMC6 give good results, isn't it? But why these differences...?
Thanks for your help, YSI
