I exported my project, DataBus2018, using the Eclipse GCC ARM selection. While the project compiles flawlessly in the online compiler, when I compiled it offline the following error was generated:
cc1: fatal error: /filer/workspace_data/exports/e/ea69a66d683e3188f4e6b0dc0053339d/DataBus2018/mbed_config.h: No such file or directory
compilation terminated.
The error traces to this line in the Makefile...
ASM_FLAGS += /filer/workspace_data/exports/e/ea69a66d683e3188f4e6b0dc0053339d/DataBus2018/mbed_config.h
Upon changing this line to:
ASM_FLAGS += mbed_config.h
...the compile completed successfully1.  If I were a gambling man, I'd wager that the long path above is a temporary path used by the export code, and whatever code generates the Makefile, it either used an absolute path to mbed_config.h or neglected to take the basename or something along those lines.
Thanks much!
1. Before I ever reached this error in the first place I had many compile errors to fix, a story I will leave for another thread.
Thanks much!
