Important changes to forums
We’re making some changes to the Mbed forums. From 10th December 2019 all new discussions will take place on our new forum site. You can continue to reply to existing threads for the next two weeks. After that we will archive this forum so you can return to useful posts in the future.
mbed M0 Beta Feedback
06 Dec 2011
Hi Sam,
I did change the USB connectod and did not notice that the order of D+ D- were swapped. It is working now.
Thanks, Mike
17 Dec 2011
I know this may seem stupid, but the very first thing I did when connecting the mbed M0 board to my computer was to... make room in the USB drive, and delete the mbed.htm file (as I already had the mbed website open in my web browser).
Later I found out the file contained the license key and I was lucky enough to be able to undelete the file.
I strongly suggest the mbed team renames the mbed.htm file to license.htm file or something like this so that people know the file is not only a shortcut to the mbed website, but also (and most importantly) the license file !
Again, I know this may seem stupid, but seriously, I am pretty sure I will not be the only one to make that mistake, so...
Hope this helps Bertrand
17 Dec 2011
Bertrand,
with the original mbed the mbed.html reappeared 'automagically' when you restarted the mbed.
Did that not happen with the M0?
Romilly
17 Dec 2011
<<quote romilly>> with the original mbed the mbed.html reappeared 'automagically' when you restarted the mbed.
Did that not happen with the M0?<</quote>>
You're right, the file came back. Phew! Thanks for the clarification.
19 Dec 2011
Is there any update to the issue of M0 mbed memory performance, as noted in my post of 2 Nov?
Hexley Ball wrote:
M0 mbed memory performance:
The program below writes a 2KB block of data to the mbed flash. It takes about 30 seconds to do the write. The same program takes 89 mS on the M3 mbed.
I tried updating to version 38 of the library, but no change in results. Is there another library that would be better to use?
-hb
03 Jan 2012
Simon Ford wrote:
For those who keep close eye on the details of NXP chips and delve in to this code, note that the implementation is not taking advantage of the ROM drivers, as our beta chip samples don't contain the ROM.
Do the mbed LPC11U24's available through distribution have the ROM drivers?
05 Jan 2012
Hexley Ball wrote:
M0 mbed memory performance: The program below writes a 2KB block of data to the mbed flash. It takes about 30 seconds to do the write. The same program takes 89 mS on the M3 mbed.
This is due to the C standard libraries we are using:
  • M3: ARM C standard library
  • M0: ARM microlib
Microlib gives a tremendous advantage on the code space (very precious on the M0), but unfortunately all its stdio streams are unbuffered. This means that for each byte of the stream, it has to pass through the whole software stack.
You have to keep in mind that the microlib stdio streams where originally designed mainly to provide printf capabilities.
We are currently proposing a different stdio streams "space vs performance" trade-off to the ARM team maintaining microlib.
Cheers, Emilio
05 Jan 2012
Yes.
Cheers, Emilio
05 Jan 2012
Thanks for the explanation, Emilio. Unfortunately, it sounds like the solution is not right around the corner. That is a pity since, as noted by Igor S. back in November, "...Hopefully the issue won't be too hard to fix because it's unusable in current state."
Here's a random suggestion: would it be possible to add a new function to the mbed library that would allow direct access to the on-card memory without going through the file system? Something like the following:
#include   "mbed.h"
RawMemory  mbedflash;
   mbedflash.write(intdata, address);
   mbedflash.write_byte(bytedata, address);
   (int) result = mbedflash.read(address);
   (char) result = mbedflash.read_byte(address);
That's a bit rough, but you get the idea.
I'd gladly give up the filesystem and write raw data if it meant I could get reasonable performance. Just a thought...
-hb
05 Jan 2012
Hexley Ball wrote:
would it be possible to add a new function [...] that would allow direct access to the on-card memory without going through the file system?
Yes, it is possible. Tomorrow I'll make sure all the required API is available to do that.
Cheers, Emilio
06 Jan 2012
Oooooooo ..
What is RawMemory
Sounds interesting
Cheers
Ceri
06 Jan 2012
OK, I modified the library to allow the access to the underling LocalFileHandle class. This will give you two ways to write files on the local mbed storage:
(1) The usual standard library file system (preferred on the M3):
    LocalFileSystem local("local");
    FILE *fp = fopen("/local/test.dat", "w");
    fwrite(buf, sizeof(buf[0]), sizeof(buf)/sizeof(buf[0]), fp);
    fclose(fp);
(2) A new way bypassing the standard library file system (preferred on the M0):
    FILEHANDLE fh = local_file_open("test.dat", O_WRONLY);
    LocalFileHandle lfh(fh);
    lfh.write(buf, sizeof(buf));
    lfh.close();
This has the advantage of practically reusing the same code in both cases, it simply bypasses a layer (the microlib fwrite that was calling lfh.write with a buffer of length 1 for each byte in the buffer passed to it).
It is available in the latest library release: Revision 34.
Cheers, Emilio
06 Jan 2012
This looks very promising, and I am eager to give it a try.
Thanks for the quick work, Emilio!
-hb
You need to log in to post a reply
