SDFileSystem.cpp line 122 ..
#include "SDFileSystem.h" #include "mbed_debug.h" #define SD_COMMAND_TIMEOUT 5000 #define SD_DBG 0 SDFileSystem::SDFileSystem(PinName mosi, PinName miso, PinName sclk, PinName cs, const char* name) : FATFileSystem(name), _spi(mosi, miso, sclk), _cs(cs), _is_initialized(0) { _cs = 1; // Set default to 100kHz for initialisation and 1MHz for data transfer _init_sck = 100000; _transfer_sck = 1000000; }The above part cause the following error on the terminal.
Terminal output
IT is obvious that the min freq. should be at least 156250 for my NUCLEO L476RG. Shouldn't this line be calculating the correct min frequency Independent to the MCU frequency? Why is this hard coded? thanks
