Error -230, The build system did not finish successfully
15 Sep 2015
I have trouble with compiling my program since today. It says; Error -230, The build system did not finish successfully.
Someone else having troubles with the online compiler?
note: a simple blinky program compiles fine...
15 Sep 2015
Hi Robin,
I'll pass this onto someone to have a look at. In the meantime it looks like your compiles were running fine before you updated your mbed library, if you can downgrade that again I think it should start working again.
Steve
15 Sep 2015
@Robin,
are you using beta or not? did you change anything? Updated mbed library for example?
15 Sep 2015
no, did not changed or updated anything, i'll try to use an older mbed library
15 Sep 2015
I used an mbed library from a program that compiles, does this mean that there is a bug in the newest mbed library?
My problem is solved for now...
16 Sep 2015
Solved how? There was a bug reported for ARMCC, which was fixed probably 2 months ago, reference https://github.com/mbedmicro/mbed/pull/1021. I believe you were getting this error and should be fixed in the newer mbed libraries, we can look up when this was integrated.
We are slowly moving to newer compiler version, this problem might appear therefore recommended to update mbed library. I was told this internal fault will be fixed in the compiler.
16 Sep 2015
I created the project, 4 days, 5 hours ago. Then I copied files from previous project to this project.
I remember that I compiled the program successfully, but yesterday I just wouldn't compile anymore.
I removed the mbed library and replaced it with an mbed library from a project created: march 3, 2015. And this worked...
If you want me to test something else, just let me know.
Regards Robin.
16 Sep 2015
Please provide the version of the mbed library (check revision), the current version is 106.
16 Sep 2015
It compiles fine with revision 94 When I use the latest library 106; "Error -230, The build system did not finish successfully."
16 Sep 2015
OK, thanks. We need to reproduce this, I tried to build locally RTOS demo , did not fail. I'll try to use latest mbed lib and some RTOs demos around to see if they fail. Do u have beta enable here?
16 Sep 2015
Don't think I have beta enable?
Could you give me more information, should I register or something?
16 Sep 2015
There is no beta running at the moment so don't worry about that.
If you want to enable beta mode you can do so by visiting http://developer.mbed.org/betamode/ at other times it may give you access to new features.
23 Sep 2015
I have the same problem. I'm following the sparkfun tutorial and getting stuck with Experiment 5: https://learn.sparkfun.com/tutorials/mbed-starter-kit-experiment-guide/experiment-5-internet-clock
The project stops compiling with error -230 as soon as I add the following dependency: https://developer.mbed.org/users/sparkfun/code/mbed-rtos/ This is mbed-rtos forked (but not modified) by SparkFun in Nov 2014
Since this is part of a tutorial, it surely must have compiled at some time.
23 Sep 2015
@Tobias, that RTOs is outdated and as referenced above, you might be getting that internal compiler fault (ARMCC). CAn you use official repo mbed-rtos , not a fork made by sparkfun?
23 Sep 2015
Thanks for the answer, yes official mbed-rtos works. But I wouldn't consider that a fix, but merely a workaround.
The purpose of the SparkFun fork was exactly to prevent that an experiment suddenly starts failing. The code was obviously working with some older version of armcc, so (given that it's correct C++) it should continue to work. If not, this is a bug in armcc which should be fixed. Same with my own code. I don't want it to fail suddenly after a year or so without touching anything.
Additionally, the error is rather unspecific. There's no hint to the cause of the error at all. The build system is a bit of a black box.
But thanks anyway and sorry for the rant ;-)
24 Sep 2015
Yes, it's workaround.
It is bug in armcc which we reported. it was fixed and that release might be out at the moment - I don't track the release log ;) We recently updated armcc but that internal fault is still present in that version :/
Yes, the error should be more descriptive - as it is reported when you compile offline. I'll report this.
09 Jul 2019
I have the same bug, yesterday my code compiled, but not today. Anyone in 2019?
17 Jul 2019
Yep, weirdly just recently.
