Error in sample program for the PCF8574 library
28 Feb 2010
In the sample program for the PCF8574, the address for the PCF8574 is shown as 0x20. The PCF8574 has a base address of  0x40 ( and the 74A has a base address of 0x70)
I've wired up a PCF8574 and the sample program works if you change the 0x20 to 0x40
Also, the comments indicate that the code toggles the pins. Actually, since the value sent out is only 0x0f, only port pins 0-3 actually toggle. Changing the value to 0xff makes them all toggle.
28 Feb 2010
The sample is probably using the old version of library where the address was 7 bits. In the current version the address is 8 bits, including the r/w bit.
See here for details.
28 Feb 2010
Thanks Igor. I've just started playing with my new mbed 4 hours ago, so wasn't aware of the old library. Having worked with I2C peripherals using AVR chips etc., I know that the LSB is the R/W bit, and figured that this probably the cause of the mixup. I think I'll be trying Microchip's MCP23016 16 bit I/O expander next.
Looks to me  like the ARM chip/mbed environment/board is going to be great! Even after only  a few hours on the site, I can see that you are one of the experts!
