Operating system
Development tools
Security and connectivity
I've noticed this before on the LPC11U24 and LPC11U35, heap and stack collision is definitely broken/disabled. I stumbled across a forum post from a few years ago about heap and stack collision being broken when the RTOS was in use, and that it had to be disabled to make it work. I'm guessing they may have disabled it across the board at that time in lieu of only disabling it if the RTOS was in use.
Indeed I know in the past it was broken, and in RTOS still kinda. But while I first used RTOS, I actually moved my program away from it since I suspected it of stealing my memory. And sure it uses a bunch of memory, but definately not the source of my memory dissapearing.
Now I don't have RTOS in use anymore, but in the past as you say they had broken heap/stack collision by disabling the check (although that was fixed long time ago). And in theory that could still account for "new" crashing. But my problem here is actually the opposite: It returns a NULL pointer long before I see a reason for it to return one. From the ARM information center:
One-region model
The application stack and heap grow towards each other in the same region of memory. See Figure 7. In this run-time memory model, the heap is checked against the value of the stack pointer when new heap space is allocated, for example, when malloc() is called.
From this I read it should keep allocating as long as the heap will not collide with the current stack pointer.
However what I get is:
Mallocced 2048 bytes at 268436144, Left over = 25864 Mallocced 2048 bytes at 268438200, Left over = 23808 Mallocced 2048 bytes at 268440256, Left over = 21752 Mallocced 2048 bytes at 268442312, Left over = 19696 Mallocced 2048 bytes at 268444368, Left over = 17640 Mallocced 2048 bytes at 268446424, Left over = 15584 Mallocced 2048 bytes at 268448480, Left over = 13528 Mallocced 2048 bytes at 268450536, Left over = 11472 Mallocced 2048 bytes at 268452592, Left over = 9416 Mallocced 2048 bytes at 268454648, Left over = 7360 Mallocced 2048 bytes at 268456704, Left over = 5304 Mallocced 2048 bytes at 0, Left over = 268462008
This one is slightly modified compared to previous one. Left over is the current stack pointer, minus the heap pointer, minus the amount I am allocating: It is how much memory should be left over after that allocation. So I have over 5kB left, yet I cannot allocate another 2kB? Why not? Also 4kB of memory has been placed on the stack by me here, which is why it starts at 26k left after the first malloc.
There is also the two-region model, which is less flexible and not used with the mbed setup. However the values are set to be able to use it, and they are set such that the heap is allowed to grow up to the heap limit, which is the initial stack pointer. Since I defined a 4kB block of memory on the stack, if I enable the two-region memory this is the result:
#pragma import __use_two_region_memory
Mallocced 2048 bytes at 268436144, Left over = 25864 Mallocced 2048 bytes at 268438200, Left over = 23808 Mallocced 2048 bytes at 268440256, Left over = 21752 Mallocced 2048 bytes at 268442312, Left over = 19696 Mallocced 2048 bytes at 268444368, Left over = 17640 Mallocced 2048 bytes at 268446424, Left over = 15584 Mallocced 2048 bytes at 268448480, Left over = 13528 Mallocced 2048 bytes at 268450536, Left over = 11472 Mallocced 2048 bytes at 268452592, Left over = 9416 Mallocced 2048 bytes at 268454648, Left over = 7360 Mallocced 2048 bytes at 268456704, Left over = 5304 Mallocced 2048 bytes at 268458760, Left over = 3248 Mallocced 2048 bytes at 268460816, Left over = 1192 Mallocced 2048 bytes at 268462872, Left over = -864 Mallocced 2048 bytes at 268464928, Left over = -2920 Mallocced 2048 bytes at 0, Left over = 268462008
So now it happily stays allocating until it reaches the top of the SRAM memory (the initial stack pointer), and I have effectively disabled the collision detection. Of course that is far from ideal, on the other hand if they collide generally your program is going to crash anyway (you can check if a NULL pointer is returned on large allocations of memory, but you cannot check each small one, and new variables on the stack don't have collision detection anyway: They can be happily placed on the heap memory).
Of course this is a very simple program, normally it will crash once the heap and stack collide, only because I am just allocating the memory here, and it is only colliding with an unused array, nothing happens. So later I hope I am able again to try what is going to happen with my program which lacked memory when I set it to use the two-region memory model: Is there actually a reason why the correct model stops 4-5kB before it should stop, or do I simply have that much more memory when it is set on two-region model.
The only thing I can think of myself, is that it is a 'safety-margin' which is built-in: So the stack always has plenty of space to grow, since the stack has no collision detection. However then why isn't this indicated in the arm info center (http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.dui0471c/CHDJEDFG.html), and secondly, 4-5kB as safety margin is a ridiculous large amount on a device which as 16kB memory total. 512B sounds more reasonable to me.
Still would be nice to have some input from mbed staff, or someone else who actually knows how it is supposed to work :)
Hello erik,
does new return null ? I can't find how ARMCC is set in the online compiler regarding exceptions, but new might throw an exception (if exceptions are enabled), or just signal the end of the application. Use new with std::nothrow by default (can't recall if ARM lib does support new with no exceptions). As result, malloc is preferred in "our" world.
Regarding failing malloc prematurely. I am not able to find ARMCC malloc implementation so I was stepping through disassmebly a bit. The rt_heap_expand function subtracts 0x1000 from the stack pointer, so therefore it leaves some space as you have noticed. That would explain 4kB of difference, plus some overhead inside and we are at the numbers you shared.
One more thing to consider, I believe printf uses malloc to allocate internal buffers, that can also reduce the size of heap.
0xc0170
Hey,
Thanks for the reply. New does not return NULL and just crashes (or signals end of application :P). Exceptions should be disabled inside the online compiler at least.
Printf also uses malloc indeed, which is why sometimes I had it crash, simply because it would succeed in allocating my test array, but then the printf function fails. But since the test array was allocated first, and nicely returns a NULL pointer when it failed, I knew it couldn't be printf being a problem: if printf in the function itself mallocs data this does not affect the mallocing of the array. If it mallocs the first time it runs data, then this just takes some heap space, but since I calculated the amount of space left using the stack pointer and the returned malloc pointer, this is already taken into account.
But then we come at the interesting part, the disassembly. So it substracts 4kB from the stack pointer, add some overhead, and that i was mallocing fairly large blocks, and we indeed exactly get what I observed. Now I assume that is indeed so the stack still has some space to grow, since the stack has no collision detection.
Now I don't know what others think about it, but to me reserving 4kB of memory on a device with 16kB of memory just to be sure your stack doesn't collide seems enormous overkill to me. Especially since in practise the result is simply that you have 4kB less memory before your program stops functioning. And the question then: Can this is changed? Or would the entire heap_extend function be reimplemented.
...but in the past as you say they had broken heap/stack collision by disabling the check (although that was fixed long time ago).
When I tested heap/stack collision detection a few months ago, it crashed in the most fantastic way with gibberish spewing all over the terminal and everything. I just re-tested it using your code, and sure enough, unless the LPC11U24 has 31KB of RAM that nobody knows about, I'd say it's still broken:
Start i is at 268443616 Mallocced 1024 bytes at 268435824, diff = 7796 Mallocced 1024 bytes at 268436856, diff = 6764 Mallocced 1024 bytes at 268437888, diff = 5732 Mallocced 1024 bytes at 268438920, diff = 4700 Mallocced 1024 bytes at 268439952, diff = 3668 Mallocced 1024 bytes at 268440984, diff = 2636 Mallocced 1024 bytes at 268442016, diff = 1604 Mallocced 1024 bytes at 268443048, diff = 572 Mallocced 1024 bytes at 268444080, diff = -460 Mallocced 1024 bytes at 268445112, diff = -1492 Mallocced 1024 bytes at 268446144, diff = -2524 Mallocced 1024 bytes at 268447176, diff = -3556 Mallocced 1024 bytes at 268448208, diff = -4588 Mallocced 1024 bytes at 268449240, diff = -5620 Mallocced 1024 bytes at 268450272, diff = -6652 Mallocced 1024 bytes at 268451304, diff = -7684 Mallocced 1024 bytes at 268452336, diff = -8716 Mallocced 1024 bytes at 268453368, diff = -9748 Mallocced 1024 bytes at 268454400, diff = -10780 Mallocced 1024 bytes at 268455432, diff = -11812 Mallocced 1024 bytes at 268456464, diff = -12844 Mallocced 1024 bytes at 268457496, diff = -13876 Mallocced 1024 bytes at 268458528, diff = -14908 Mallocced 1024 bytes at 268459560, diff = -15940 Mallocced 1024 bytes at 268460592, diff = -16972 Mallocced 1024 bytes at 268461624, diff = -18004 Mallocced 1024 bytes at 268462656, diff = -19036 Mallocced 1024 bytes at 268463688, diff = -20068 Mallocced 1024 bytes at 268464720, diff = -21100 Mallocced 1024 bytes at 268465752, diff = -22132 Mallocced 1024 bytes at 268466784, diff = -23164
And that is the up to date lib? (just making sure) That is again the problem of never getting a NULL pointer. Different from the other problems here, but good chance it is at least partially related.
Also weird that it doesn't crash earlier: Malloc also has to write a few bytes with information. You would think writing that to non-existent memory causes a crash.
And that is the up to date lib? That is again the problem of never getting a NULL pointer. Different from the other problems here, but good chance it is at least partially related.
Yes, revision 81.
In this companion thread, you'll see a link I found into a reference for the ARM compiler in how it operates per the C++ standard that new does not return NULL, it throws an exception instead. I don't know what's under the covers in the C++ edition, but the interface is "class-like" and constructors don't return values...
Hi everyone, Im a newbie to this forum.I found this thread to be related to my issue which im currently debugging now. Please take a look at this thread created by me https://mbed.org/questions/4220/Different-behaviors-of-New-operator-Dyna/ and requesting you to share your thoughts on this..
So a nice cryptic title.
Problem 1: When 'new' is called, it is supposed to return a NULL pointer when it fails. Currently it is simply crashing. Malloc does work correctly.
Which brings us to problem 2: I lied. On the KL05 also malloc which fails crashes. I guess uARM vs regular ARM.
Those are the easy ones, now the ones I can also probably use some feedback on. The issue, I got a program which runs out of memory sooner than I would expect. I won't bore you with the program, so lets go to the test program:
Now from what I understand of the memory model, i and i2 start at the top, everything new which is malloced/new'ed start at the bottom. When they touch each other you are screwed (technically mallocing should be about wherever it fits, but in this simple case that description should be correct afaik.
Now the results, on the KL05Z: (with 512 bytes increment, since it is fairly small):
It never returns the NULL pointer (here it could also be crashing on the printf, but I tried other increments also). This looks fine to me.
Now on the KL46Z, but same for some others:
So the good part is that is nicely returns a NULL pointer. The bad news is that it does so when there should be over 5kB of memory left. For the KL25Z and LPC1768 I get values between 4kB and 5kB of memory left.
How is this possible. Even if there would be overhead, how can it be there? i2 is created right there at the bottom of the stack. Test is malloced right there at the top of the heap. Is there some overhead I am not aware of that accounts for 4-5kB of SRAM memory? Did Sam add a bitcoin miner to the code? Is the NSA watching us?
So TL;DR: New doesn't fail correctly, malloc not on uARM (that might be by design, dunno), and something is stealing my memory. It is by the way done with latest mbed lib, non-beta compiler. Few versions older mbed lib has the same behavior.
