main.cpp
//1KB sound effect table (8-bit signed, 2000Hz sample rate)
signed char soundEffectTable[] = {
0x01,0x03,0x09,0x10,0x16,0x17,0x12,0x07,0xFB,0xEF,0xE6,0xE3,0xE5,0xE9,0xEF,0xF5,
0xFB,0x01,0x09,0x10,0x15,0x18,0x16,0x0E,0x02,0xF5,0xEC,0xE8,0xEA,0xF0,0xF8,0xFE,
0x02,0x04,0x04,0x04,0x04,0x04,0x03,0x02,0x01,0x00,0xFF,0x01,0x04,0x09,0x0E,0x10,
0x0F,0x08,0xFD,0xEF,0xE0,0xD2,0xC7,0xC1,0xC0,0xC5,0xD0,0xE0,0xF4,0x0B,0x22,0x38,
0x4A,0x56,0x5A,0x55,0x47,0x30,0x14,0xF7,0xDC,0xC8,0xBE,0xBE,0xC8,0xDA,0xF0,0x06,
0x1B,0x2B,0x32,0x30,0x25,0x12,0xFC,0xE7,0xD6,0xCE,0xD0,0xDC,0xF0,0x08,0x21,0x36,
0x45,0x4B,0x4A,0x42,0x36,0x27,0x17,0x08,0xFC,0xF5,0xF2,0xF3,0xF8,0xFC,0xFF,0xFB,
0xF2,0xE3,0xD1,0xC0,0xB4,0xAF,0xB3,0xC0,0xD3,0xEC,0x06,0x1E,0x33,0x41,0x49,0x49,
0x42,0x33,0x20,0x0B,0xF5,0xE3,0xD5,0xCC,0xC9,0xCB,0xD1,0xDA,0xE4,0xEF,0xF8,0x00,
0x05,0x09,0x0A,0x0A,0x08,0x06,0x05,0x03,0x03,0x04,0x05,0x07,0x0A,0x0E,0x11,0x14,
0x17,0x19,0x1A,0x1B,0x1C,0x1C,0x1B,0x1A,0x18,0x15,0x12,0x0F,0x0A,0x06,0x01,0xFC,
0xF7,0xF2,0xED,0xEA,0xE6,0xE4,0xE3,0xE2,0xE2,0xE4,0xE6,0xE8,0xEC,0xEF,0xF3,0xF6,
0xFA,0xFD,0x00,0x03,0x05,0x06,0x07,0x07,0x07,0x06,0x05,0x04,0x02,0x00,0xFF,0xFD,
0xFB,0xF9,0xF8,0xF6,0xF5,0xF4,0xF4,0xF3,0xF3,0xF4,0xF5,0xF6,0xF7,0xF8,0xFA,0xFB,
0xFC,0xFC,0xFD,0xFD,0xFE,0xFF,0x00,0x01,0x02,0x04,0x06,0x09,0x0C,0x0F,0x12,0x15,
0x17,0x1A,0x1B,0x1C,0x1C,0x1C,0x1A,0x18,0x16,0x13,0x10,0x0D,0x0A,0x06,0x04,0x01,
0xFF,0xFD,0xFC,0xFB,0xFA,0xF9,0xF9,0xF9,0xF9,0xF8,0xF8,0xF7,0xF6,0xF5,0xF4,0xF4,
0xF3,0xF2,0xF1,0xF1,0xF0,0xF0,0xF0,0xF0,0xF1,0xF1,0xF1,0xF2,0xF3,0xF4,0xF4,0xF5,
0xF6,0xF8,0xF9,0xFA,0xFB,0xFD,0xFE,0xFF,0x00,0x01,0x02,0x03,0x04,0x04,0x04,0x04,
0x04,0x04,0x05,0x05,0x05,0x06,0x06,0x07,0x08,0x0A,0x0B,0x0C,0x0D,0x0E,0x0F,0x10,
0x10,0x10,0x10,0x10,0x0F,0x0F,0x0E,0x0D,0x0D,0x0C,0x0B,0x09,0x08,0x06,0x05,0x03,
0x01,0x00,0xFE,0xFD,0xFC,0xFB,0xFA,0xFA,0xF9,0xF9,0xF9,0xF9,0xF8,0xF8,0xF8,0xF8,
0xF7,0xF7,0xF6,0xF5,0xF5,0xF4,0xF3,0xF2,0xF2,0xF1,0xF1,0xF2,0xF2,0xF3,0xF4,0xF5,
0xF6,0xF7,0xF8,0xF9,0xFA,0xFA,0xFB,0xFC,0xFD,0xFD,0xFE,0xFF,0x01,0x02,0x04,0x05,
0x06,0x08,0x09,0x0A,0x0B,0x0C,0x0C,0x0D,0x0D,0x0D,0x0D,0x0D,0x0D,0x0D,0x0D,0x0D,
0x0C,0x0B,0x0A,0x09,0x08,0x07,0x06,0x05,0x04,0x04,0x04,0x04,0x04,0x04,0x04,0x04,
0x04,0x04,0x04,0x03,0x03,0x02,0x02,0x01,0x01,0x00,0xFF,0xFE,0xFC,0xFA,0xF9,0xF7,
0xF5,0xF3,0xF2,0xF0,0xEE,0xEC,0xEB,0xEB,0xEC,0xEE,0xEF,0xEE,0xEC,0xE9,0xE9,0xED,
0xF4,0xFD,0x07,0x11,0x16,0x14,0x0C,0xFF,0xEF,0xE1,0xDA,0xDD,0xE8,0xFA,0x0F,0x24,
0x33,0x3B,0x39,0x2E,0x1C,0x07,0xF2,0xE2,0xD7,0xD2,0xD6,0xDF,0xEE,0xFE,0x0F,0x1F,
0x2C,0x37,0x3E,0x42,0x41,0x3B,0x31,0x22,0x10,0xFC,0xE7,0xD3,0xC2,0xB6,0xB3,0xB8,
0xC7,0xDE,0xFA,0x17,0x30,0x40,0x47,0x44,0x3A,0x2B,0x1C,0x0E,0x01,0xF5,0xEA,0xE0,
0xD8,0xD3,0xD2,0xD5,0xDB,0xE6,0xF4,0x04,0x15,0x24,0x2F,0x35,0x33,0x27,0x11,0xF4,
0xD4,0xB6,0xA0,0x94,0x94,0xA1,0xB8,0xD5,0xF4,0x11,0x29,0x38,0x3F,0x3D,0x35,0x2B,
0x1F,0x14,0x0B,0x04,0x00,0xFF,0x00,0x04,0x0C,0x15,0x20,0x2A,0x32,0x37,0x37,0x31,
0x26,0x17,0x05,0xF4,0xE3,0xD6,0xCB,0xC3,0xBF,0xBD,0xBD,0xC1,0xC8,0xD3,0xE1,0xF2,
0x05,0x18,0x2A,0x38,0x43,0x4A,0x4D,0x4C,0x49,0x43,0x3A,0x30,0x23,0x14,0x05,0xF9,
0xEF,0xEA,0xE7,0xE6,0xE5,0xE2,0xDB,0xCF,0xC1,0xB2,0xA4,0x9A,0x96,0x9B,0xA8,0xBC,
0xD6,0xF2,0x0D,0x24,0x36,0x40,0x44,0x41,0x39,0x2F,0x23,0x18,0x0E,0x05,0xFF,0xFC,
0xFC,0xFF,0x05,0x0D,0x15,0x1A,0x1C,0x19,0x11,0x06,0xFA,0xEF,0xE7,0xE3,0xE4,0xEA,
0xF3,0xFD,0x06,0x0E,0x13,0x15,0x14,0x10,0x0C,0x09,0x08,0x0A,0x0F,0x16,0x1E,0x24,
0x29,0x2B,0x29,0x25,0x1E,0x15,0x0A,0x00,0xF5,0xEB,0xE1,0xD9,0xD2,0xCD,0xC9,0xC8,
0xC9,0xCD,0xD3,0xDA,0xE2,0xEA,0xEF,0xF1,0xF1,0xED,0xE8,0xE1,0xDC,0xD8,0xD7,0xDB,
0xE2,0xED,0xFC,0x0C,0x1D,0x2D,0x3B,0x45,0x4B,0x4D,0x4A,0x44,0x3C,0x33,0x2A,0x22,
0x1A,0x13,0x0C,0x05,0xFE,0xF7,0xF0,0xE9,0xE3,0xDF,0xDD,0xDE,0xE0,0xE4,0xE8,0xEB,
0xED,0xEC,0xEA,0xE6,0xE2,0xDF,0xDD,0xDE,0xE2,0xE9,0xF2,0xFE,0x0B,0x19,0x26,0x33,
0x3E,0x45,0x4A,0x4B,0x49,0x43,0x3C,0x32,0x28,0x1C,0x11,0x06,0xFA,0xEF,0xE4,0xD9,
0xCF,0xC6,0xBF,0xBA,0xB7,0xB8,0xBB,0xC1,0xC8,0xD2,0xDC,0xE6,0xF0,0xF9,0x01,0x08,
0x0D,0x11,0x13,0x16,0x18,0x1A,0x1C,0x1E,0x20,0x21,0x21,0x20,0x1D,0x19,0x13,0x0C,
0x05,0xFF,0xFB,0xF8,0xF7,0xF9,0xFB,0xFF,0x02,0x05,0x06,0x06,0x04,0x02,0xFE,0xFB,
0xF9,0xF7,0xF7,0xF9,0xFC,0x00,0x05,0x0A,0x0E,0x11,0x12,0x12,0x0F,0x0B,0x06,0x00,
0xFB,0xF8,0xF6,0xF7,0xFA,0xFE,0x03,0x08,0x0C,0x0F,0x0F,0x0D,0x08,0x01,0xF7,0xEE,
0xE5,0xDE,0xD9,0xD8,0xD9,0xDD,0xE3,0xE9,0xF0,0xF4,0xF7,0xF8,0xF7,0xF4,0xF1,0xEE,
0xED,0xEE,0xF1,0xF7,0xFE,0x06,0x0F,0x18,0x20,0x26,0x2A,0x2C,0x2B,0x29,0x25,0x20,
0x1B,0x15,0x10,0x0B,0x06,0x01,0xFC,0xF7,0xF2,0xED,0xE9,0xE6,0xE5,0xE7,0xEA,0xEF,
0xF7,0xFF,0x07,0x0F,0x16,0x1A,0x1D,0x1D,0x1A,0x16,0x10,0x09,0x02,0xFC,0xF7,0xF3,
0xF1,0xF1,0xF1,0xF3,0xF4,0xF6,0xF8,0xF9,0xFA,0xFA,0xFA,0xFA,0xF9,0xF8,0xF8,0xF7,
0xF7,0xF7,0xF7,0xF9,0xFB,0xFE,0x02,0x05,0x09,0x0B,0x0D,0x0E,0x0D,0x0B,0x07,0x02,
0xFD,0xF9,0xF5,0xF3,0xF2,0xF2,0xF4,0xF6,0xF9,0xFC,0xFE,0xFF,0xFF,0xFE,0xFE,0xFD,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
Ticker audioTicker;
PwmOut pwmOut(p26);
volatile int idx;
void onAudioTicker()
//Load the next sample
pwmOut = ((int)soundEffectTable[idx++] + 127) / 255.0;
//Check if we're done
if (idx >= 1024) {
idx = 0;
audioTicker.detach();
//Configure the PWM output for class D style audio (200kHz)
pwmOut.period_us(5);
//Play the sound effect every 2.0 seconds
//Start the ticker at a sample rate of 2000Hz
audioTicker.attach_us(&onAudioTicker, 500);
wait(2.0);
Hey guys. I'm trying to play some sound effects using PWM (just like a class D amplifier), but I'm having trouble getting my code to work on the LPC11U24. When the sound effect plays, there's another tone being overlaid on top of it at the sample frequency. In the case of my attached code, there's a 2kHz square wave being played on top of the sound effect. My theory is that changing the duty cycle is introducing a glitch in the output that's manifesting as a square wave. The same code runs fine on an LPC1768. Is there any possibility this is a software problem and not a hardware problem? I should mention, I've tried using FastPWM without success.
main.cpp
#include "mbed.h" //1KB sound effect table (8-bit signed, 2000Hz sample rate) signed char soundEffectTable[] = { 0x01,0x03,0x09,0x10,0x16,0x17,0x12,0x07,0xFB,0xEF,0xE6,0xE3,0xE5,0xE9,0xEF,0xF5, 0xFB,0x01,0x09,0x10,0x15,0x18,0x16,0x0E,0x02,0xF5,0xEC,0xE8,0xEA,0xF0,0xF8,0xFE, 0x02,0x04,0x04,0x04,0x04,0x04,0x03,0x02,0x01,0x00,0xFF,0x01,0x04,0x09,0x0E,0x10, 0x0F,0x08,0xFD,0xEF,0xE0,0xD2,0xC7,0xC1,0xC0,0xC5,0xD0,0xE0,0xF4,0x0B,0x22,0x38, 0x4A,0x56,0x5A,0x55,0x47,0x30,0x14,0xF7,0xDC,0xC8,0xBE,0xBE,0xC8,0xDA,0xF0,0x06, 0x1B,0x2B,0x32,0x30,0x25,0x12,0xFC,0xE7,0xD6,0xCE,0xD0,0xDC,0xF0,0x08,0x21,0x36, 0x45,0x4B,0x4A,0x42,0x36,0x27,0x17,0x08,0xFC,0xF5,0xF2,0xF3,0xF8,0xFC,0xFF,0xFB, 0xF2,0xE3,0xD1,0xC0,0xB4,0xAF,0xB3,0xC0,0xD3,0xEC,0x06,0x1E,0x33,0x41,0x49,0x49, 0x42,0x33,0x20,0x0B,0xF5,0xE3,0xD5,0xCC,0xC9,0xCB,0xD1,0xDA,0xE4,0xEF,0xF8,0x00, 0x05,0x09,0x0A,0x0A,0x08,0x06,0x05,0x03,0x03,0x04,0x05,0x07,0x0A,0x0E,0x11,0x14, 0x17,0x19,0x1A,0x1B,0x1C,0x1C,0x1B,0x1A,0x18,0x15,0x12,0x0F,0x0A,0x06,0x01,0xFC, 0xF7,0xF2,0xED,0xEA,0xE6,0xE4,0xE3,0xE2,0xE2,0xE4,0xE6,0xE8,0xEC,0xEF,0xF3,0xF6, 0xFA,0xFD,0x00,0x03,0x05,0x06,0x07,0x07,0x07,0x06,0x05,0x04,0x02,0x00,0xFF,0xFD, 0xFB,0xF9,0xF8,0xF6,0xF5,0xF4,0xF4,0xF3,0xF3,0xF4,0xF5,0xF6,0xF7,0xF8,0xFA,0xFB, 0xFC,0xFC,0xFD,0xFD,0xFE,0xFF,0x00,0x01,0x02,0x04,0x06,0x09,0x0C,0x0F,0x12,0x15, 0x17,0x1A,0x1B,0x1C,0x1C,0x1C,0x1A,0x18,0x16,0x13,0x10,0x0D,0x0A,0x06,0x04,0x01, 0xFF,0xFD,0xFC,0xFB,0xFA,0xF9,0xF9,0xF9,0xF9,0xF8,0xF8,0xF7,0xF6,0xF5,0xF4,0xF4, 0xF3,0xF2,0xF1,0xF1,0xF0,0xF0,0xF0,0xF0,0xF1,0xF1,0xF1,0xF2,0xF3,0xF4,0xF4,0xF5, 0xF6,0xF8,0xF9,0xFA,0xFB,0xFD,0xFE,0xFF,0x00,0x01,0x02,0x03,0x04,0x04,0x04,0x04, 0x04,0x04,0x05,0x05,0x05,0x06,0x06,0x07,0x08,0x0A,0x0B,0x0C,0x0D,0x0E,0x0F,0x10, 0x10,0x10,0x10,0x10,0x0F,0x0F,0x0E,0x0D,0x0D,0x0C,0x0B,0x09,0x08,0x06,0x05,0x03, 0x01,0x00,0xFE,0xFD,0xFC,0xFB,0xFA,0xFA,0xF9,0xF9,0xF9,0xF9,0xF8,0xF8,0xF8,0xF8, 0xF7,0xF7,0xF6,0xF5,0xF5,0xF4,0xF3,0xF2,0xF2,0xF1,0xF1,0xF2,0xF2,0xF3,0xF4,0xF5, 0xF6,0xF7,0xF8,0xF9,0xFA,0xFA,0xFB,0xFC,0xFD,0xFD,0xFE,0xFF,0x01,0x02,0x04,0x05, 0x06,0x08,0x09,0x0A,0x0B,0x0C,0x0C,0x0D,0x0D,0x0D,0x0D,0x0D,0x0D,0x0D,0x0D,0x0D, 0x0C,0x0B,0x0A,0x09,0x08,0x07,0x06,0x05,0x04,0x04,0x04,0x04,0x04,0x04,0x04,0x04, 0x04,0x04,0x04,0x03,0x03,0x02,0x02,0x01,0x01,0x00,0xFF,0xFE,0xFC,0xFA,0xF9,0xF7, 0xF5,0xF3,0xF2,0xF0,0xEE,0xEC,0xEB,0xEB,0xEC,0xEE,0xEF,0xEE,0xEC,0xE9,0xE9,0xED, 0xF4,0xFD,0x07,0x11,0x16,0x14,0x0C,0xFF,0xEF,0xE1,0xDA,0xDD,0xE8,0xFA,0x0F,0x24, 0x33,0x3B,0x39,0x2E,0x1C,0x07,0xF2,0xE2,0xD7,0xD2,0xD6,0xDF,0xEE,0xFE,0x0F,0x1F, 0x2C,0x37,0x3E,0x42,0x41,0x3B,0x31,0x22,0x10,0xFC,0xE7,0xD3,0xC2,0xB6,0xB3,0xB8, 0xC7,0xDE,0xFA,0x17,0x30,0x40,0x47,0x44,0x3A,0x2B,0x1C,0x0E,0x01,0xF5,0xEA,0xE0, 0xD8,0xD3,0xD2,0xD5,0xDB,0xE6,0xF4,0x04,0x15,0x24,0x2F,0x35,0x33,0x27,0x11,0xF4, 0xD4,0xB6,0xA0,0x94,0x94,0xA1,0xB8,0xD5,0xF4,0x11,0x29,0x38,0x3F,0x3D,0x35,0x2B, 0x1F,0x14,0x0B,0x04,0x00,0xFF,0x00,0x04,0x0C,0x15,0x20,0x2A,0x32,0x37,0x37,0x31, 0x26,0x17,0x05,0xF4,0xE3,0xD6,0xCB,0xC3,0xBF,0xBD,0xBD,0xC1,0xC8,0xD3,0xE1,0xF2, 0x05,0x18,0x2A,0x38,0x43,0x4A,0x4D,0x4C,0x49,0x43,0x3A,0x30,0x23,0x14,0x05,0xF9, 0xEF,0xEA,0xE7,0xE6,0xE5,0xE2,0xDB,0xCF,0xC1,0xB2,0xA4,0x9A,0x96,0x9B,0xA8,0xBC, 0xD6,0xF2,0x0D,0x24,0x36,0x40,0x44,0x41,0x39,0x2F,0x23,0x18,0x0E,0x05,0xFF,0xFC, 0xFC,0xFF,0x05,0x0D,0x15,0x1A,0x1C,0x19,0x11,0x06,0xFA,0xEF,0xE7,0xE3,0xE4,0xEA, 0xF3,0xFD,0x06,0x0E,0x13,0x15,0x14,0x10,0x0C,0x09,0x08,0x0A,0x0F,0x16,0x1E,0x24, 0x29,0x2B,0x29,0x25,0x1E,0x15,0x0A,0x00,0xF5,0xEB,0xE1,0xD9,0xD2,0xCD,0xC9,0xC8, 0xC9,0xCD,0xD3,0xDA,0xE2,0xEA,0xEF,0xF1,0xF1,0xED,0xE8,0xE1,0xDC,0xD8,0xD7,0xDB, 0xE2,0xED,0xFC,0x0C,0x1D,0x2D,0x3B,0x45,0x4B,0x4D,0x4A,0x44,0x3C,0x33,0x2A,0x22, 0x1A,0x13,0x0C,0x05,0xFE,0xF7,0xF0,0xE9,0xE3,0xDF,0xDD,0xDE,0xE0,0xE4,0xE8,0xEB, 0xED,0xEC,0xEA,0xE6,0xE2,0xDF,0xDD,0xDE,0xE2,0xE9,0xF2,0xFE,0x0B,0x19,0x26,0x33, 0x3E,0x45,0x4A,0x4B,0x49,0x43,0x3C,0x32,0x28,0x1C,0x11,0x06,0xFA,0xEF,0xE4,0xD9, 0xCF,0xC6,0xBF,0xBA,0xB7,0xB8,0xBB,0xC1,0xC8,0xD2,0xDC,0xE6,0xF0,0xF9,0x01,0x08, 0x0D,0x11,0x13,0x16,0x18,0x1A,0x1C,0x1E,0x20,0x21,0x21,0x20,0x1D,0x19,0x13,0x0C, 0x05,0xFF,0xFB,0xF8,0xF7,0xF9,0xFB,0xFF,0x02,0x05,0x06,0x06,0x04,0x02,0xFE,0xFB, 0xF9,0xF7,0xF7,0xF9,0xFC,0x00,0x05,0x0A,0x0E,0x11,0x12,0x12,0x0F,0x0B,0x06,0x00, 0xFB,0xF8,0xF6,0xF7,0xFA,0xFE,0x03,0x08,0x0C,0x0F,0x0F,0x0D,0x08,0x01,0xF7,0xEE, 0xE5,0xDE,0xD9,0xD8,0xD9,0xDD,0xE3,0xE9,0xF0,0xF4,0xF7,0xF8,0xF7,0xF4,0xF1,0xEE, 0xED,0xEE,0xF1,0xF7,0xFE,0x06,0x0F,0x18,0x20,0x26,0x2A,0x2C,0x2B,0x29,0x25,0x20, 0x1B,0x15,0x10,0x0B,0x06,0x01,0xFC,0xF7,0xF2,0xED,0xE9,0xE6,0xE5,0xE7,0xEA,0xEF, 0xF7,0xFF,0x07,0x0F,0x16,0x1A,0x1D,0x1D,0x1A,0x16,0x10,0x09,0x02,0xFC,0xF7,0xF3, 0xF1,0xF1,0xF1,0xF3,0xF4,0xF6,0xF8,0xF9,0xFA,0xFA,0xFA,0xFA,0xF9,0xF8,0xF8,0xF7, 0xF7,0xF7,0xF7,0xF9,0xFB,0xFE,0x02,0x05,0x09,0x0B,0x0D,0x0E,0x0D,0x0B,0x07,0x02, 0xFD,0xF9,0xF5,0xF3,0xF2,0xF2,0xF4,0xF6,0xF9,0xFC,0xFE,0xFF,0xFF,0xFE,0xFE,0xFD, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00 }; Ticker audioTicker; PwmOut pwmOut(p26); volatile int idx; void onAudioTicker() { //Load the next sample pwmOut = ((int)soundEffectTable[idx++] + 127) / 255.0; //Check if we're done if (idx >= 1024) { idx = 0; audioTicker.detach(); } } int main() { //Configure the PWM output for class D style audio (200kHz) pwmOut.period_us(5); //Play the sound effect every 2.0 seconds while (1) { //Start the ticker at a sample rate of 2000Hz audioTicker.attach_us(&onAudioTicker, 500); wait(2.0); } }
