Wrong SRAM definition in the LPC4088.ld linker script
21 Dec 2013
Hello
The linker script LPC4088.ld is copied from the LPC1768.ld without adjudge the SRAM size. The LPC4088 have 96K (64K + 16K + 16K) SRAM and the LPC1768 have 64K (32K + 16K + 16K) SRAM.
See also section 7.6 in http://www.nxp.com/documents/data_sheet/LPC408X_7X.pdf
So I think the sram line in the linker script LPC4088.ld should look like this: RAM (rwx) : ORIGIN = 0x100000E8, LENGTH = (64K - 0xE8)
Greetings Daniel
07 Jan 2014
Hi Daniel,
You are correct. We will add it to our todo list of things to update in the LPC4088 port.
Thanks, Andreas @ Embedded Artists
