Hi Marin,
Converting a library to folder is as easy as right-clicking the folder and selecting "Convert to Folder". This effectively de-versions your library and turns it to a simple folder, which means you can no longer use separate versioning for it, though it is still versioned in the parent program (or library if the folder parent is a library).
to 2: If you are planning to import from your computer, then you can open the Import Wizard and switch to the "Upload" tab, where you can click "Add" to browse and select files from your local machine. Once ready with the files of your choice, just click "Import".
Alternatively when using Chrome, Firefox or Opera (basically every browser except Internet Explorer) you can open your OS file manager (Windows Explorer on Windows, Finder on Mac) and just drag and drop multiple files from your local machine directly over your workspace in the mbed IDE.
In both upload methods uploading a folder is not permitted due to browsers (and standards) limitations. If you wish to upload a folder or a whole structure of folders then just ZIP it and use either of the described upload methods above.
You can find detailed information on how to fine tune the import/upload process in the Import Code handbook page.
You can also watch the Introduction to the mbed Online Compiler video if you haven't already, which briefly covers the life cycle of a code - from revision control and publishing to distributed version control, collaboration and a lot more.
Cheers,
Mihail
Hello mbed users,
I have been finally using online compiler to publish my own libraries (most of them are offline at the moment though). I am going to add my findings, what I have encountered so far.
Perhaps those I included, are not bugs at all and there are ways to do what I needed, any suggestions are welcome.
0xc0170
