Hi Igor, sorry for the delay.
Here is a "demo" highlighting the problem ( USB cord used ).
When I siwtched from local file system to USB stick in my project, I moved the writings in main().
Thanks for your support!
- include "mbed.h"
int done = 0; boolean
DigitalOut myled(LED1);
LocalFileSystem local("local"); Create the local filesystem under the name "local"
FILE *fp;
void InitRTC()
{ struct tm t;
t.tm_sec = 0; 0-59
t.tm_min = 0; 0-59
t.tm_hour = 0; 0-23
t.tm_mday = 1; 1-31
t.tm_mon = 0; 0-11
t.tm_year = 70; year since 1900
set_time(mktime(&t)); Jan 1 00:00:00 1970, sothat timestamp starts at 0
LPC_RTC->CCR = 0; RTC is stopped until acquisition is started
NB: time() restarts the RTC !
LPC_RTC->CIIR = 1; Select interrupts, 1=seconds
LPC_RTC->ILR = 3; Clear the counter increment interrupt and the alarm interrupt flags
extern "C" void RTC_IRQHandler()
{ if(done == 0)
{ if (LPC_RTC->MIN == 0)
{ myled = 1;
fprintf(fp, "%i: Hello World!", LPC_RTC->SEC);
wait(0.1);
myled = 0;
else
{ fclose(fp);
myled = 1;
done = 1;
LPC_RTC->ILR = 1; Clear the counter increment interrupt flag
{ InitRTC();
fp = fopen("/local/out.txt", "w"); Open "out.txt" on the local file system for writing
LPC_RTC->CCR = 1; Start RTC
NVIC_EnableIRQ(RTC_IRQn);
while(1){} COMMENT OUT THIS LINE AND THE WRITINGS FAIL !
I am developing a slow rate (battery powered) data logger SW. I intend in a first time to store data in the local file system (flash memory). When I use fwrite() in a handler, if the main program does not end with a while(1) { }, fwrite fails (returns 0)... Why ?
