newlib-nano
04 Jan 2018
Quote:
If you are using Mbed's RTOS, do not use newlib-nano!
However, if you run your Mbed OS application in a single thread (or have removed the RTOS), ... using newlib-nano can bring signifcant benefits.
Please consider publicizing this more widely, e.g. documenting in connection with mbed export. I did use newlib-nano for a time - when I was experimenting with MCUXpresso managed linker scripts, IIRC.
04 Jan 2018
Or better yet, fix the problem so newlib-nano can be used.
Is newlib-nano an Arm property? Or can you make feature requests there?
09 Feb 2018
Can I use the eventQueue if enable the newlib-nano and single thread ?
12 Mar 2019
Late reply I know, but yes, EventQueue works perfectly with newlib-nano and without RTOS.
