12 years, 7 months ago.
Where are Pin definitions?
I see that LED1 is used in a file. I guessed LED2 was a pin name, It worked, Know I need one of the analog inputs.
Here the pin assignments are shown: http://mbed.org/handbook/mbed-FRDM-KL25Z
In addition there are a few more defined, such as LED1, LED2 (those are actually only for compatibility with LPC programs), USBTX + USBRX for serial connection over USB (they also refer to the programming USB port, not the one connected to the KL25 chip itself), all pin definitions can be found here: http://mbed.org/users/mbed_official/code/mbed-Freescale/file/d5f2f3e8f628/capi/KL25Z/PinNames.h
The link above for PinNames.h does not work! Can you fix it please?
posted by Herschel Hall 16 Nov 2013
This one should work: http://mbed.org/users/mbed_official/code/mbed-src/file/bebbbd80dd87/targets/hal/TARGET_Freescale/TARGET_KL25Z/PinNames.h
If it changes again, search for mbed-src, then it is at targets > hal > [your manufacturer] > [your device] > PinNames.h
posted by Erik - 16 Nov 2013
