12 years, 7 months ago.
kl25z code help needed...after days of attempts.
With the following code I can send the x accelerator output to the screen, but not the y accelerator output. I have tried two whole methods of extracting it, using a function call with a pointer, as well as using separate functions for each axis, but the same code that works for the x accelerator will not extract the y accelerator value and average it. I have left the common function in the code as well as my printf statements that I tried to use to debug the code. I am not an experienced c programmer, but I have spent days trying to solve this. I'd sure appreciate some help.
#include "MMA8451Q.h"
#define MMA8451_I2C_ADDRESS (0x1d<<1)
const int number_times = 5;
float average_x[number_times], average_y[number_times], average_z[number_times];
//float array[10][10][10];
//float *array[10];
float average_value(float value, float *array);
float average_x_value(float value);
float average_y_value(float value);
int main(void) {
float XaccO;
float YaccO;
float ZaccO;
// pc.printf("Hello World! \n \r");
for (int i = 0; i < number_times; ++i){
average_x[i] = 0;
average_y[i] = 0;
for (int i = 0; i < number_times; ++i){ // for (int i = 0; i <= number_times; ++i){
average_z[i] = 0;
MMA8451Q acc(PTE25, PTE24, MMA8451_I2C_ADDRESS);
PwmOut rled(LED_RED);
PwmOut gled(LED_GREEN);
PwmOut bled(LED_BLUE);
while (true) {
rled = 1.0 - abs(acc.getAccX());
gled = 1.0 - abs(acc.getAccY());
bled = 1.0 - abs(acc.getAccZ());
// wait(1);
XaccO = acc.getAccX();
YaccO = acc.getAccY();
ZaccO = abs(acc.getAccZ());
pc.printf("Hello World again! \n \r");
pc.printf("Xacc0= ");
pc.printf("%f", XaccO);
pc.printf(" ");
pc.printf("%f", average_x_value(XaccO)); //, average_x));
// pc.printf("%f", average_value(XaccO, average_x)); I was able to get x average with this function, using a pointer
pc.printf(" = Average X \r");
pc.printf("\n");
pc.printf("Yacc0= ");
pc.printf("%f", YaccO);
pc.printf(" ");
pc.printf("%f", average_y_value(YaccO));
// pc.printf("%f", average_value(YaccO, average_y)); my failed attempt to get y average using a common function and a pointer
pc.printf(" = Average Y \r");
pc.printf("\n");
// pc.printf("%f", ZaccO);
wait(10);
pc.printf(" \r");
pc.printf("\n");
pc.printf(" \r");
pc.printf("\n");
pc.printf(" \r");
pc.printf("\n");
//try using a common function with a pointer (with no success):
//pointer example:
// float aray=1.5;
// float *addpointer; //define *addpointer as a pointer to a variable that is a floating point number
// addpointer = &aray; // addpointer now points to the value that is named aray
// pc.printf("addpointer= ");
// pc.printf("%f",addpointer);
//end of example
pc.printf(" float *array= ");
pc.printf("%f",array);
pc.printf(" ");
float total;
int i;
for(i = (number_times-1); i >= 0; i--)
array[i+1] = array[i];
array[0] = value;
// pc.printf("value");
// pc.printf("%f", value); // value and array[0] are the same
pc.printf("\r");
pc.printf("\n");
pc.printf("array[0]= ");
pc.printf("%f", array[0]);
pc.printf(" \r");
pc.printf("\n");
total = 0;
for(i = 0; i<number_times; i++)
total = array[i] + total;
pc.printf("array[i]= ");
pc.printf("%f", array[i]);
pc.printf(" Total= ");
pc.printf("%f", total);
pc.printf(" number_times= ");
pc.printf("%d", number_times);
pc.printf(" ");
pc.printf(" \r");
pc.printf("\n");
return (total/number_times);
//calculate the average x value:
float total;
int i;
for (i = (number_times-1); i >= 0; i--)
average_x[i+1] = average_x[i];
average_x[0] = value;
total = 0;
for (i = 0; i<number_times; i++)
total = average_x[i] + total;
//calculate the average y value (failed)
float total;
int i;
average_y[i+1] = average_y[i];
average_y[0] = value;
total = 0;
total = average_y[i] + total;
There is something wrong in the calculation of the average. The arrays should have indexes between 0 and (number_times-1). Your code accesses average_y[i+1] with i=number_times-1. This is outside the array. Same problem for x. Do you see any values for y coming from the sensor before averaging?
float total;
int i;
total = 0;
Both the Y and X values come successfully from the sensor. The code successfully averages the X value, but the same code does not average the Y value. The Y values do not get into the array. I am puzzled as to why the same code does not work for Y as it does for X. The function that uses the pointer also averages X correctly, but not Y. Very puzzled. I will re-think your answer about the indexes. Maybe I am not seeing this correctly. Thanks again.
posted by 29 Apr 2013The code accesses the array between 0 and 4, as I read it (in the "for loop" ). The number_times constant is set to 5 at the beginning of the program. The for loop stops it from decrimenting when it reaches 0, as I understand it.
posted by 29 Apr 2013The first loop will result in i values 4, 3, 2, 1, 0
// The i values lead to
// average_y[5] = average_y[4]; //illegal
// average_y[4] = average_y[3];
// average_y[3] = average_y[2];
// average_y[2] = average_y[1];
// average_y[1] = average_y[0];
The second loop will result in i values 0, 1, 2, 3, 4
// The i values lead to a total that is the sum of all 5 values
