12 years, 11 months ago.
API Doc and examples ?
Do you have any pointers to the API doc and examples ?
The full manual with the API description can be generated (from .text) from the official repository
https://github.com/tass-belgium/picotcp
Clone the repo, enter the "docs/user_doc" directory, run build.sh A PDF from today's snapshot is attached here.
Please note that we just started the integration with mbed-rtos, so this is a very early version. You can import the library to your project, but with the following limitations:
- The generic driver based on ethernet_api.h does not use IRQ/DMA, so don't expect a high throughput - The stack is running in a single thread - You have to use our legacy (non Berkeley) API
The team is currently working full time on those three points. We will deliver a much better version, optimized for the LPC1768 mbed platform in the very next days.
Thanks!
/d
/media/uploads/daniele/user_doc.pdf
