12 years, 11 months ago.
fputc definition
I intend to do a port of some of the mbed library to another device so that I can reuse some libraries that I've written for mbed. The two libraries that are of most interest are SPI and Serial.
I can understand all of the workings of the SPI library and believe I can implement it on the other device. I'm struggling however with the Serial library. In the Stream library which Serial inherits from, the putc member function calls std::fputc
int Stream::putc(int c) {
    fflush(_file);
    return std::fputc(c, _file);
Somehow fputc calls the Serial::_putc member function, but I can't find a definition of fputc anywhere in the mbed library. Please could someone tell me where the c code for fputc is or how the Serial::_putc method is called from it?
Thanks, Tim
fputc is part of the C standard library.
You can find its documentation here.
As an example, you can find the newlib implementation here.
HTH, Emilio
Tim Barry
poster
Thanks Emilio
