12 years, 11 months ago.
Timer for interrupts
Hi
Could you tell me what is the best method for measuring time between rise and falling period of interrupts? When I implemented Timer into my code it wasn't working. Below, is my code which increments the counter whenever there is a rise.
Thanks
void pulseLeft();
void pulseRight();
void pulseStop();
int countLeft = 0;
int countRight = 0;
 ir_rx0.rise(&pulseRight);
 ir_rx0.fall(&pulseStop);
    while(true);
void pulseRight()
    countRight++;
    printf("COUNT_RIGHT = : %d\n",  countRight);
    if(countRight == 32)
    countRight = 0;
Which timescale are you looking at? But in principle, just use a timer. If that didn't work post the code that didn't work.
Piotr Galek
poster
I am looking at microseconds
here is the bit of code that uses timer. its main purpose is to measure time it to decrement. is this is what I shupossed to do?
void pulseLeft()
    int begin;
    int end;
    timer.start();
    begin = timer.read_us();
    countLeft--;
    end = timer.read_us();
    timer.stop();
    printf("difference = : %d\n", end - begin);
    //printf("COUNt_LEFT = : %d\n",  countLeft);
    if(countLeft == 0)
      //ticks++
      countLeft = 32;
Now it just measures how long it takes to decrease countLeft by one (that doesn't take long). In your question you said you wanted to measure time between rising and falling edges of the interrupt, so then you need to start the timer on the rising edge function, and stop it on the falling edge function.
posted by Erik - 23 Apr 2013
