6 years, 4 months ago.
Help Simplifying an FRAM example code
I've been trying rack my brain around understanding how to store data externally like a datalog.
Essentially I have a fuel gauge which tells me how many cycles of charge the battery has undertaken, but when the unit gets switched off I lose that data.
I was thinking I should save that data on an external FRAM chip we have, which is an MB85RS64 (Adafruit module), remarkably the example code works which I have gotten from:
https://os.mbed.com/components/Fujitsu-SPI-FRAM-MB85RSxx/
but I do not understand how to simplify it down to a few things I need I wanted to store the following data:
Number of Charges: (the number has decimals too)
Run time: Seconds, Minutes, Hours & days
Number of times the unit been switched off
The example code so far has arrays which I do not understand properly if someone can explain that bit in layman's terms would be very helpful. Also, how would I store strings of words or numbers to this type of FRAM and how much data do you think I can store for a 64Kbit / 8KByte.
I have attached the code and tried to comment bits to understand I may have commented wrongly but would be helpful if anyone can point out. Also, I noticed the while loop doesn't continue too which I do not know why?
main.
#include "MB85RSxx_SPI.h"
DigitalOut myled(LED1);
Serial pc(USBTX, USBRX);
//#if defined(TARGET_LPC1768)
//MB85RSxx_SPI fram(p5, p6, p7, p8); // mosi, miso, sclk, cs
//#elif defined(TARGET_LPC1114)
//MB85RSxx_SPI fram(dp2, dp1, dp6, dp9); // mosi, miso, sclk, cs
//#else // Arduino R3 Shield form factor
MB85RSxx_SPI fram(D11, D12, D13, D10); // mosi, miso, sclk, cs
//#endif
uint8_t buf[16];
uint32_t address;
pc.baud(115200);
pc.printf("\nFujitsu MB85RSxxx FRAM test program\n\n");
// Read device ID and detect memory density for addressing
fram.read_device_id(buf);
pc.printf("read device ID = 0x%x 0x%x 0x%x 0x%x\n", buf[0], buf[1], buf[2], buf[3]);
fram.write_enable();
pc.printf("read status (WREN) = 0x%x\n", fram.read_status());
fram.write_disable();
pc.printf("read status (WRDI) = 0x%x\n", fram.read_status());
// Write 0 data
fram.fill(0, 1, 256);
// Prepare write data
for (int i = 0; i < 16; i++) {
buf[i] = i;
//============ Write Data To FRAM ========================
// Write data with write enable
fram.write(0x00, buf, 16);
// Attempt to write data (not written)
fram.write(0x10, buf, 16);
fram.write(0x20, buf, 16);
//============= Read Data From FRAM ======================
// Read data
for (address = 0; address < 0x80; address += 16) {
fram.read(address, buf, 16);
pc.printf("%08X : ", address);
pc.printf("%02X ", buf[i]);
pc.printf("\n");
//============ Write a Number to address ================
// Write number from 0 to 255
pc.printf("\n");
for (address = 0; address < 0x100; address++) {
fram.write(address, (uint8_t)address);
//============ Read From Address Location ================
// Read data
for (address = 0; address < 0x100; address += 16) {
pc.printf("\n");
myled = 1;
wait(1);
myled = 0;
wait(1);
I hope to hear from you soon!
Mohammed Al-Amin
