6 years, 5 months ago.
Control classic Servo Motor with STM32 and Mbed library
I'm using STM32 F401RE board and i'm trying to do a very simple thing. I want to control a servo (0-180). The problem is that it looks like it doesn't respound to my commands.
PwmOut myServo(D9);
    myServo.period_ms(20);
    while(1)
        myServo.pulsewidth_ms(1);
The Servo Motor i'm using. At the beginning i though something is wrong with my board pinout or pinout meaning, but it seems like D9 is the same with PC_7. My servo is properly installed and is supplyed by 5V source. I tried many tutorials i've found online but no one worked.
If i generate the same PWM with an oscilloscope it does work.
Hi there,
That part of code need to be before the while loop I think.
Check the documentation and examples about PwmOut.
  • Try to check this page about a SERVO.
  • When you use different power supply for the servo then to power the MCU, you need to have connected all GND together I think.
  • PC_7 is standard marking of the seventh pin on Port C of the chip and D9 is marking what according to the arduino header. D9 and PC_7 is one same pin (line 137).
BR, Jan
I recommened to use name PC_7 -> PwmOut myServo(PC_7);
Regards, Pekka
