6 years, 4 months ago.
CAN at PIN PA11,PA12
i bought a STM32F446ZEJ6 Chip and designd a own Board with this Controller. Everything works fine, i can upload code and use pins for blinky etc. But if i use the Pins PA11,PA12 for a CAN-Bus communication, nothing happens.
I write the code in the mbed online editor and compile the code with NUCLEO-F446ZE. If i compile the code with NUCLEO-F446RE and load it on the STM32F446ZEJ6 , the CAN-Bus communication works.
Maybe the compiler blocks the function on PA11,PA12 because they are used for USB_DM and USB_DP on the NUCLEO-F446ZE developementboard? Is there any solution to run the code on the mentioned pins with the compiler for the NUCLEO-F446ZE plattform?
Nice greetings
STM32 Nucleo-144 development board with STM32F446ZE MCU, supports Arduino, ST Zio and morpho connectivity
Hello Martin,
I don't have a NUCLEO-F446ZE board to test it but you can try to remove the USB driver by adding a mbed_app.json configuration file to the project:
mbed_app.json
    "target_overrides": {
            "device_has_remove": ["USBDEVICE"]
